unsuccessful re-install of OS for PineBookPro
14" PineBook Pro, purchased in late 2022
I stood up the desktop and had it just starting working
I wanted to upgrade to the latest Manjaro ARM kde Plasma for PBP v22.12
as I followed the directions, my system only gets to green power LED, no screen, no sound  - I'm stuck.
I do not recall interrupting the process, although at this point I am not ruling it out.
I would like to get the PBP laptop stood up to a desktop environment for Plasma/Manjaro
(02-12-2023, 08:10 AM)Valiance Wrote: 14" PineBook Pro, purchased in late 2022
I found the switch for the eMMC to allow it to boot microSD and got an install stood up.    I cannot access the SSD however.  still working on it.
SSD ??? Do you mean emmc or nvme ?
If emmc, it it is just a question of timing, when to flip the disable switch back to enable
It has to be long enough for the 3rd choice, SD to start loading idbloader (& then uboot,, from SD)
but not too long, before uboot finishes its device enumeration
So.. press pwr button 1 sec, wait 2-3 sec, flip switch
lsblk to see if you got it right, emmc has the boot0, boot1 sections on it (rk3399 does not use these, ignore)
Or, there are the unbind/ bind commands, search forum
If you mean nvme, usually because it wants too much power,
I don't know the commands to put it to power state 2
Thank you.  Switching the eMMC worked. Had a little struggle with when to switch it back, but got it figured out. Smile
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 8 18,731 06-26-2025, 09:20 PM
Last Post: reukiodo
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,357 02-19-2025, 12:49 PM
Last Post: zkajdan
  Doing a fresh install docFarto 5 7,047 02-09-2025, 02:58 PM
Last Post: mikehenson
  Void Linux: missing firmware from pinebookpro-firmware? remph 0 3,366 12-15-2024, 01:58 PM
Last Post: remph
  Attempting to install Void Linux, boots into a black screen 9a3eedi 1 6,885 09-28-2024, 09:23 AM
Last Post: throwawayforvoid
  install debian on pbp jsch 7 12,296 11-22-2023, 04:22 PM
Last Post: TRS-80
  Install deepin OS on pinebook pro wangyukunshan 4 6,808 08-07-2023, 01:12 PM
Last Post: myself600
  Blank screen after Armbian 20.04 install to emmc? psychoacoustic 3 9,588 04-01-2023, 03:22 PM
Last Post: TRS-80
  Unsuccessful using danielt's unofficial Debian installer on the PBP joeDoe 2 5,902 12-09-2022, 05:04 AM
Last Post: ndp
  Tow Boot install help Paulie420 7 11,276 11-24-2022, 10:24 AM
