Doing a fresh install
My friend gave me their old Pinebook Pro 14" after not using it very much.
They do not remember the password, so I would like to put a fresh install onto it.
They got this one in 2022 I believe.
I have a couple of questions I have not able find answers to on the forums.
firstly I have seen this: https://wiki.pine64.org/wiki/Pinebook_So...0181028.5D
but I am not sure what the standard OS on pinebook is. I do not want to do anything fancy just get the original OS and flash it on.
So what is the standard OS for the Pinebook Pro?
Also is flashing that OS on through micro SD the best method for a fresh install.
Thanks for reading, any help is appreciated!
(02-02-2025, 12:31 PM)docFarto Wrote: but I am not sure what the standard OS on pinebook is. I do not want to do anything fancy just get the original OS and flash it on.
I just installed PostMarketOS on my PineBookPro. Easy and painless. Wifi works, I have not tried much more yet.
https://images.postmarketos.org/bpo/
Get image, unzip image, put on SD, put in PineBookPro.
Boot off SD, Get image again on PineBookPro, unzip image, dd to the eMMC
Turn off PineBook, take SD out, Turn on PineBookPro
The original OS and the current standard OS are both considered obsolete.
If you can live with a very small WiFi dongle, and don't mind tinkering; NetBSD works very well on this computer. Else, maybe do try Postmarket OS. (I haven't tried that)
:wq
Personally, I'd recommend installing Tow Boot to SPI (https://tow-boot.org/devices/pine64-pinebookPro.html) and then Fedora to eMMC (https://download.fedoraproject.org/pub/f...h64.raw.xz) It was incredibly easy for me to install despite using outdated installation documentation (no longer needed, just write Tow Boot to SPI, write the installer to SD, boot from SD, and start installing!) By F36/7 everything's been working wonderfully!
Armbian is also easy to install, as well as Arch (thanks to archinstall)
If you want to check out what your other options are, you can find them here: https://pine64.org/documentation/Pineboo.../Releases/
(02-04-2025, 08:49 AM)tophneal Wrote: Personally, I'd recommend installing Tow Boot to SPI (https://tow-boot.org/devices/pine64-pinebookPro.html) and then Fedora to eMMC (https://download.fedoraproject.org/pub/f...h64.raw.xz)
Does Tow-Boot display a menu for you?
I just went through numerous attempts to install a current Linux distro on my Pinebook Pro. Installing Tow-Boot to SPI was helpful, but it just shows a blank screen at boot and without knowing what was displayed on the menu I ended up switching off the eMMC switch to get it to boot from an SD card with a mangled bootloader on the eMMC.
Ultimately, I ended up with a Debian install on the eMMC with SPI Tow-Boot, and it seems to be working well. It wasn't exactly straightforward to get to that point though.
(02-09-2025, 10:36 AM)recalcitrant_rain Wrote: Does Tow-Boot display a menu for you?
Yes, You have to press ESC when it boots
[Image: attachment.php?aid=2913]
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 8 18,807 06-26-2025, 09:20 PM
Last Post: reukiodo
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,397 02-19-2025, 12:49 PM
Last Post: zkajdan
  Attempting to install Void Linux, boots into a black screen 9a3eedi 1 6,931 09-28-2024, 09:23 AM
Last Post: throwawayforvoid
  install debian on pbp jsch 7 12,320 11-22-2023, 04:22 PM
Last Post: TRS-80
  Install deepin OS on pinebook pro wangyukunshan 4 6,830 08-07-2023, 01:12 PM
Last Post: myself600
  Blank screen after Armbian 20.04 install to emmc? psychoacoustic 3 9,614 04-01-2023, 03:22 PM
Last Post: TRS-80
  unsuccessful re-install of OS for PineBookPro Valiance 3 5,247 02-14-2023, 12:49 PM
Last Post: Valiance
  Tow Boot install help Paulie420 7 11,310 11-24-2022, 10:24 AM
  How can I install Debian? ImmyChan 1 6,514 10-19-2022, 03:09 AM
Last Post: alpopa
Information Install Void Linux with near-full-disk encryption dumetrulo 3 9,319 09-05-2022, 12:00 PM
Last Post: petersen77
