new manjaro install: wlan0 stuck in setting network address
I am following this post:
https://forum.pine64.org/showthread.php?tid=10403
to install current Manjaro on the ponebook. So far, I have successfully installed Manjaro 23.02 on the sd card.
But from the new sd card installation, I cannot use wifi to download an image for the emmc install:
wlan0 is forever hanging in "connecting"/"setting network address".
ip link shows the interface as dormant. NetworkManager is running, and the nameserver setting is correct in /etc/resolv.conf. I can also ping the nameserver.
But ip route does not return anything.
Would anyone have an idea what is going wrong? Many thanks in advance!!
At this point, I can only recommend trying another distribution:
https://blog.strits.dk/is-manjaro-arm-dead/
Manjaro ARM stable has not been updated for months, not even with security updates.
So sorry, I didn't get notified of your answer! Thank you so much!
Can you recommend a distribution to install now?
Thanks again!
(02-03-2025, 05:06 AM)zkajdan Wrote: So sorry, I didn't get notified of your answer! Thank you so much!
Thanks again!
I just installed PostMarketOS on my PineBookPro. Easy and painless. Wifi works, I have not tried much more yet.
https://images.postmarketos.org/bpo/
Get image, unzip image, put on SD, put in PineBookPro.
Boot off SD, Get image again on PineBookPro, unzip image, dd to the eMMC
Turn off PineBook, take SD out, Turn on PineBookPro
Thanks Mike! That's good to know!
I have a problem getting the PBP to start from the sd card I burnt postmarket OS to - see new thread https://forum.pine64.org/showthread.php?tid=19701.
Perhaps @mikehenson could you take a look at that thread? Thank you so much!!
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,555 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 8 18,657 06-26-2025, 09:20 PM
Last Post: reukiodo
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 6,188 03-15-2025, 01:47 AM
Last Post: frank_philip
  Doing a fresh install docFarto 5 6,996 02-09-2025, 02:58 PM
Last Post: mikehenson
  Attempting to install Void Linux, boots into a black screen 9a3eedi 1 6,844 09-28-2024, 09:23 AM
Last Post: throwawayforvoid
  Manjaro Sway Theme Broken Eighty8 1 4,083 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 6,625 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 3,966 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,225 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 11,458 12-11-2023, 03:47 AM
Last Post: calinb
