pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery]
I decided to try with manjaro arm again. I've got it running but recently my device seems to be unable to most needed hardware. It seems to think it has no wifi, or blutooth and I can't see the battery status(seems to think it's always on wired power)
Has anyone encountered this issue before? I've currently got this issue when I boot from sd card(with Manjaro-ARM-gnome-pbpro-23.02) or from the emmc.
Hi, I sometimes have that issue too, mostly after resuming from suspend. After a proper poweroff (no reboot, I think the WiFi chip needs to be power cycled) it's back.
I am running plain Arch though, not Manjaro, with 6.12.1
For the last couple of months, I have an issue closer to the one from the second poster.
The wifi chip (dongle) is not responding around every 5th boot so the kernel driver brcmfmac fails to upload its firmware. That happens independent of the operating system and kernel version.
That is the expected flow:
[  12.039720] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43456-sdio for chip BCM4345/9 [  12.040287] usbcore: registered new interface driver brcmfmac [  13.631747] brcmfmac: brcmf_c_process_txcap_blob: no txcap_blob available (err=-2) [  13.632060] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/9 wl0: Feb 11 2020 11:54:51 version 7.45.96.61 (be7af2d@shgit) (r745790) FWID 01-a41d86bd es7.c5.n4.a3 [  18.648148] ieee80211 phy0: brcmf_c_set_cur_etheraddr: Setting cur_etheraddr failed, -52
That is the flow where the wifi chip (dongle) is non-responsive:
[  11.368358] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43456-sdio for chip BCM4345/9 [  11.370328] usbcore: registered new interface driver brcmfmac [  11.871130] ieee80211 phy0: brcmf_c_preinit_dcmds: Default MAC is used, replacing with random MAC to avoid conflicts [  11.871702] ieee80211 phy0: brcmf_c_set_cur_etheraddr: Setting cur_etheraddr failed, -52 [  11.871726] ieee80211 phy0: brcmf_bus_started: failed: -52 [  11.871755] ieee80211 phy0: brcmf_attach: dongle is not responding: err=-52 [  11.955157] brcmfmac: brcmf_sdio_firmware_callback: brcmf_attach failed
Reloading the brcmfmac driver with rmmod / modprobe results in the same error logs - the wifi chip (dongle) remains inaccessible. It remains inaccessible with a reboot which is probably only resetting the cpu but not peripherals such as the wifi chip (dongle). Only a complete shutdown followed by a new boot gives me a 80% chance of the wifi chip (dongle) being  accessible, again. That is exactly my current workaround: shutdown and new boot.
I would recommend OP to open the laptop and re-assure that every component sits firmly. I can't imagine it's an OS problem, but in an desperate attempt one could boot another OS as well.
Thanks for the tips. Need to find some time to double check that. |
You are right it's probably not an OS problem. I noticed while trying to start it up and turn it off a few times. The clock isn't running while it's off. Time only moves on while it's powered on.
coming back to this late but it seems to have been an OS probem, I switched to postmarket os and did not have any issues with wifi or blutooth connectivity
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,652 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
Information Found newer firmware for broadcom wifi (brcmfmac43456-sdio) cobratbq 4 13,418 07-04-2025, 07:46 AM
Last Post: remph
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 8 18,885 06-26-2025, 09:20 PM
Last Post: reukiodo
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,457 02-19-2025, 12:49 PM
Last Post: zkajdan
  Improved battery life with TLP daemon Surehand53 0 3,539 12-30-2024, 07:46 AM
Last Post: Surehand53
  Manjaro Sway Theme Broken Eighty8 1 4,172 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 6,714 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 4,054 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,350 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 11,574 12-11-2023, 03:47 AM
Last Post: calinb
