Void Linux: missing firmware from pinebookpro-firmware?
I'm running Void on my pbp, which currently is working fine, but during installation wifi didn't work, and `ip a` said that wlan0 didn't exist at all, and the privacy switches didn't help. The unbind/bind trick:
sudo tee /sys/bus/platform/drivers/dwmmc_rockchip/{un,}bind <<< 'fe310000.mmc'
complained through dmesg of error -2 when looking for brcm/brcmfmac43455-sdio, which indeed didn't exist, so I copied it over from the stock Manjaro install on the eMMC (here eMMC is mounted under `/run/mount/manjaro' and void SD card is mounted under `/run/mount/void'):
cd /run/mount/manjaro/ cp --parents -Pvt ../void/ lib/firmware/{brcm/brcmfmac43455-sdio.{bin,clm_blob,'pine64,pinebook-pro.txt'},cypress/cyfmac43455.*}
Now it works. Should those files be in pinebookpro-firmware?
  Can’t login to Linux fnosai 0 3,509 07-27-2025, 12:30 AM
Last Post: fnosai
Information Found newer firmware for broadcom wifi (brcmfmac43456-sdio) cobratbq 4 13,722 07-04-2025, 07:46 AM
Last Post: remph
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 8 19,332 06-26-2025, 09:20 PM
Last Post: reukiodo
  Attempting to install Void Linux, boots into a black screen 9a3eedi 1 7,146 09-28-2024, 09:23 AM
Last Post: throwawayforvoid
  Slackware Linux working on PBP vxzero 0 4,223 06-05-2024, 04:30 PM
Last Post: vxzero
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 7,589 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 3,445 07-13-2023, 05:21 PM
Last Post: owaspfap
  Kali Linux for Pinebook Pro Luke 100 284,233 05-03-2023, 06:10 AM
Last Post: dachalife
  Missing A Few Programs on PostmarketOS on PB Pro publiclewdness 0 2,471 03-06-2023, 11:33 PM
Last Post: publiclewdness
  unsuccessful re-install of OS for PineBookPro Valiance 3 5,348 02-14-2023, 12:49 PM
Last Post: Valiance
