| Welcome, Guest |
| Latest Threads |
Article: Will Linux phone...
Last Post: zetabeta
Yesterday, 02:36 AM
» Replies: 4
Star64 Irradium (based on...
Forum: Getting Started
10-08-2026, 02:00 PM
» Replies: 21
Pinecil V2 + Raspberry Pi...
Last Post: candera
10-08-2026, 03:26 AM
» Replies: 0
SlateOS feedback needed!
Last Post: Nolegdai
10-05-2026, 02:04 PM
Unknown Startup Password ...
Forum: PineTab Hardware
10-05-2026, 12:44 PM
HDMI or VGA From Pinebook...
10-05-2026, 12:42 PM
» Replies: 7
Delivery to Ukraine
Last Post: freidepiter
10-01-2026, 12:56 PM
» Replies: 10
PINEPOCALYPSE (pics inclu...
Last Post: segaloco
09-29-2026, 11:36 PM
» Replies: 2
PineTab-V Experiences
Last Post: segaloco
09-29-2026, 11:28 PM
» Replies: 0
irradium (based on crux l...
Forum: Linux on Rock64
09-27-2026, 11:55 AM
» Replies: 14
| Manjaro [ARM Stable Update] 2021-07-23 issues |
Posted by: Bocanila - 07-24-2021, 09:09 AM - Forum: Linux on Pinebook Pro
- Replies (1)
Hi!
After updating to the latest version of Manjaro ([ARM Stable Update] 2021-07-23) my PBP's splash boot image does not appear anymore.
Only a black screen until the logging page appears.
I think this happens because the kernel boots plash was not added.
It should be like that? Is this a new feature?
Also there is one more annoying thing that happens after this update, my PBP freezes randomly and only a hard restart resolves this. Does this happen to anyone else?
| Frame Buffer GUI - Proof of Concept |
Posted by: mouffa - 07-24-2021, 05:38 AM - Forum: Arch Linux on PinePhone
- Replies (3)
Here we compile and run the LVGL library demos on Arch Linux Barebone to show that we can create useful graphics through the Frame Buffer.
https://lvgl.io/
1) Install the basic dependencies for program development
`sudo pacman -Syu base-devel`
2) Clone the relevant repositories
`git clone --recursive https://github.com/lvgl/lv_port_linux_frame_buffer`
3) Adjust to Pinephone's screen resolution
Edit the file "main.c" in "lv_port_linux_frame_buffer" and change Line 31 from 800 to 720 and Line 32 from 480 to 1440,
disp_drv.hor_res = 720;
disp_drv.ver_res = 1440;
4) Enable Touchscreen
We use the "evdev" event driver, the raw data from the touchscreen for Arch Barebone are output at "/dev/input/event1", the rest of the events in the folder are the the physical buttons and the sense of USB, headphone and vibration.
We need to edit 2 files, "lv_drv_conf.h" and "main.c"
-------- lv_drv_conf.h ----------
Line 389 should be changed to
# define USE_EVDEV 1
Line 397 should be changed to
# define EVDEV_NAME "/dev/input/event1"
--------- main.c -----------
At the beginning of the file we should include the header
#include "lv_drivers/indev/evdev.h"
Right before Line 36 where we call the demo function we should initialise the touchscreen by adding the following code
/* enable event input*/
evdev_init();
/* enable touchscreen*/
lv_indev_drv_t indev_drv;
lv_indev_drv_init(&indev_drv);
indev_drv.type = LV_INDEV_TYPE_POINTER;
indev_drv.read_cb = evdev_read;
lv_indev_drv_register(&indev_drv);
5) Compile by running `make` in "lv_port_linux_frame_buffer"
The command will generate an executable named "demo". If you want to change something and recompile then first remove all the object files of the edited files and the "demo" and `make` again.
`rm [edited-files].o`
`rm demo`
`make`
6) Run the program on Arch Linux Barebone
`./demo`
7) Exit the program pressing CTRL+C
Note :
By default the code runs the `lv_demo_widgets` demo, you can test the rest of the 5 demos by changing line 36 in "main.c" to one of the following choices
lv_demo_widgets();
lv_demo_music();
lv_demo_keypad_encoder();
lv_demo_benchmark();
lv_demo_stress();
then remove "main.o" and "demo" and `make`
`rm main.o`
`rm demo`
`make`
| on off power button stopped working |
Posted by: dcinoz - 07-24-2021, 05:07 AM - Forum: PinePhone Hardware
- Replies (3)
Another thread mentions the $1 "PINEPHONE SIDE KEYS FLEX PCB" https://forum.pine64.org/showthread.php?...3#pid91693
I just took apart the Pinephone to replace the earpiece speaker and the on/off button no longer works - or at least not very often, I have to plug in USB-C cable to turn it on. And I can't reliably turn the screen on / off with the power on/off button.
I have removed the back cover and the inner plastic cover that goes round the back - the volume / on / off flexi cable is fully inserted into the motherboard 'slot'. Vol up / down works fine, still. Looking at the side where the black and white 'cover' is on the vol up/down and on/off keys with a torch, the top of the on/off key area seems to have lots of small creases / thin vertical lines across the top half - I don't know if that would be the issue or the flexi itself?
Standard shipping to Adelaide, Australia is US$12, so very expensive US$13 total. Is there anywhere else I can buy it with more reasonable shipping?
Any suggestions as to what I could try to 'fix' this? I'm starting to realise that a lot of parts seem very fragile and can apparently be easily damaged when taking apart / putting back together. I have been very careful but you have to bend the flexi to get it back into the motherboard 'slot'.
Thanks for any advice. Anyone in Australia ordering something please let me know - it would be great to be able to reduce shipping costs. Not quite sure if I can live with it as it is. I might just switch back to my Android phone with Lineageos and without google apps!
| Chatty history disappeared after update |
Posted by: tomoqv - 07-24-2021, 04:34 AM - Forum: Manjaro on PinePhone
- No Replies
Following the latest update of chatty (chatty-0.3.3+16+g11c76c6-1-aarch64), the app no longer shows the messaging history. The database file home/manjaro/.purple/chatty/db/chatty-history.db remains and all the messages are still there, but chatty doesn't read them for some reason. I tried to downgrade chatty to an earlier version from the package cache, but same thing.
Messaging works and new chats are being displayed in chatty, but for some reason the old chats are not visible.
Any ideas?
| [phosh] boost pipewire volume beyond 100%? |
Posted by: dcinoz - 07-23-2021, 11:54 PM - Forum: Manjaro on PinePhone
- Replies (3)
My earpiece speaker broke after my Pinephone fell out of my jacket pocket. I bought a replacement speaker from aliexpress based on a post identifying compatible models but, even though it works, the volume is very low even at 100%.
With pulseaudio I would use pavucontrol to boost to 150%. Manjaro Phosh uses pipewire and pavucontrol doesn't work. Does anyone know what I can use to achieve the same result. Speaker is unusable as there is a massive echo so callers hear themselves, and I would like to be able to use the earpiece rather than having to use an earpiece - though that is the best solution, I think, once you've managed to untangle it, push in the earpieces and plug it in!
Command line would be fine, ideally something that survives reboot.
Thanks.
| docking bar limits charging rate? |
Posted by: nelstomlinson - 07-23-2021, 11:01 AM - Forum: General Discussion on PinePhone
- Replies (5)
I'm using a 1.5A USB charger, and that is barely able to charge the battery faster than I am discharging it. When I plug in that same charger through the docking bar, I see that the USB current limit is only 0.5A, and that is definitely NOT enough to keep ahead of the discharge.
Is this a known issue? Is there a fix?
This is a beta edition, convergence model, running Mobian/Phosh from the SD.
| When to dist-upgrade vs when to reinstall? |
Posted by: DrPlamsa - 07-23-2021, 07:06 AM - Forum: Mobian on PinePhone
- Replies (5)
Hello all:
When should I be satisfied with upgrading via the apt package manager, and when should I do a complete reinstall? Are there changes that occur in the updated Mobian images which are not implemented when an old installation upgrades via apt?
An example: When I installed Mobian in October 2020, full disk encryption (FDE) was not available so I had to hack together an encrypted /home/ partition using cryptsetup and LUKS. Then, some time in December, the Mobian images packaged a native FDE setup tool. If I were to reinstall now, I could set up FDE natively.
Is FDE an *exception* or the *rule*? Am I missing other important features and fixes by upgrading via apt?
Thanks again
| SFOS 4.1.0.24 aarch64 |
Posted by: defactofactotum - 07-23-2021, 03:43 AM - Forum: SailfishOS on PinePhone
- Replies (5)
The new image is an aarch64 build, so quite a departure and there are many teething problems at the moment.
Flash as usual and then as root zypper ref/ssu ur/zypper dup. Apps now need to be 64bit builds so some on the Jolla store won't install and the Openrepos Storeman app will not install either. There may be some improvement in sim card recognition but it will take some time for this build to get back to parity with the 32bit version.
| Build Infinitime Sources |
Posted by: aemkai - 07-22-2021, 01:40 PM - Forum: Development Discussion on PineTime
- Replies (4)
im a relative newbie to programming and wan't to have a own clock face.
I followed the build steps from Git - build and program and the build with a new face with some little changes was also successfull.[url=https://github.com/JF002/InfiniTime/blob/develop/doc/buildAndProgram.md][/url]
I wan't to programm the firmware by OTA/DFU, but my problem is, there wasn't a pinetime-mcuboot-app-dfu build.
The files build are: - pinetime-app-1.2.0.bin
- pinetime-app-1.2.0.hex
- pinetime-app-1.2.0.map
- pinetime-app-1.2.0.out
The dependencies as descriped on git are installed and additionally adafruit-nrfutil.
I prepare the build with
Code: cmake -DARM_NONE_EABI_TOOLCHAIN_PATH="/opt/gcc-arm-none-eabi/gcc-arm-none-eabi-10-2020-q4-major" -DNRF5_SDK_PATH="/opt/nRF5_SDK_15.3.0_59ac345" -DUSE_JLINK=0 -DNRFJPROG="/opt/nrfjprog/nrfjprog" -DCMAKE_BUILD_TYPE=Release -DBUILD_DFU=1 ../
and run the build with
Code: make -j pinetime-app
in the build-directory.
What have i done wrong. How to get an pinetime-mcuboot-app-dfu.zip?
thanks in advance
| Link USB power strips for a cluster? |
Posted by: DevonBirch - 07-22-2021, 11:03 AM - Forum: General
- Replies (4)
So Im thinking of building a Pine64 cluster for a homelab over a Pi for a couple reasons, also being able to order more than one of the same type.
Their website sells USB to barrel power adapters awesome! But I need a power strip that can output 5V 3A for at least four USB ports.
I am not honestly that familiar with power usage and finding pieces but I see a lot of 2.4Amps with a max total of 12Amps. Out of a USB power strip. Is 3A really just 2.4?192.168.0.1 routerlogin 192.168.l.l
