RISC OS Linux port
I have installed RISC OS on Linux on PineTab2 (also on PinePhone with Mobian). Is not an Emulator, is an executable. So it is very fast with the access of the hardware like WLAN etc. The screenshot are my own settings.
[Image: ROS_PineTab2.jpg]
You can download from PyraDirect . The collection I have made for the Pyra handheld based on ROD's PiDirect but works fine on PineTab.
It need base-devel as dependencies (e.g. sudo pacman -Sy base-devel)
Unpack the download in Terminal with
tar —xattrs -xvf Downloads/pyra_direct.tar.gz
to your home directory. It takes a while.
Then in Terminal…
Dir RISC_OS
./run_RISC_OS
The first start takes a bit longer.
  Working OS on pinetab RISC-V? user641 3 5,284 12-13-2023, 08:11 AM
  Arch Linux (danctnix) virtual keyboard layout change cudo 0 2,724 09-27-2023, 12:19 PM
Last Post: cudo
  Arch Linux ARM on PineTab 1 Danct12 25 49,144 06-10-2023, 05:33 PM
Last Post: fxc
Video Does DactNix Arch Linux support my use case? BlueGalaxy 22 23,631 05-18-2023, 03:45 AM
