New Pinetab- error when attempting to install updates
Just got my first Pinetab- thrilled with the quality!!
But...I can't seem to get  updates to install- have searched the web for solutions including "sudo pacman -Syu" and related variations, but no matter what  do I keep getting the following error:
"Dependency resolution failed:
libavcodec.so (followed by string of info)
libswrsample.so (followed by string of info)
libicuuc,so (followed by string of info)
Not being a dev I'm stuck at how to correct this issue- does anyone know of a solution?
Thanks!
Sorry, I have not seen this and have open an other post.
I try "sudo pacman -Syu" yesterday. All looks fine and working as long as the screensaver is not active or if no restart is performed.
The next login goes in a loop and the desktop will be never arrived.
CTRL+ALT+F2 enter the terminal. Here I can log in but no network, "startx" is not working...
After I install the latest factory image, I try to install the available actualization via Discover. The same ...
Next "factory reset" needed...
  pinetab2 danctnix broken during upgrade - shell error acruhl 6 13,264 07-23-2025, 06:27 PM
Last Post: acruhl
  PineTab (early adopters) wifi broken in kernel 6.12 bartgrefte 0 2,361 03-23-2025, 05:25 AM
Last Post: bartgrefte
  Power off error message stefan_hdb 1 3,143 04-26-2024, 10:18 AM
Last Post: moobythegoldensock
  PineTab 2 login screen rotation fix chzbacon 11 19,147 03-17-2024, 04:53 PM
Last Post: mtomaschett
  How to install Plasma Mobile in Archlinux Surehand53 14 23,733 02-28-2024, 07:07 AM
Last Post: aular
  NixOS on PineTab 2 asonix 3 8,346 02-24-2024, 12:29 PM
Last Post: Evergreen
  Working OS on pinetab RISC-V? user641 3 5,370 12-13-2023, 08:11 AM
  Mobian won't boot after ton of updates bartgrefte 11 16,770 12-10-2023, 02:47 AM
  Pinetab 2 as Pinebook Pro replacement Corkonian 4 7,976 08-15-2023, 11:22 AM
Last Post: CadenAnderson
  Software for PineTab-V msm 12 15,253 08-05-2023, 05:08 PM
Last Post: bingch
