Trying to Install Manjaro-ARM-kde-plasma-pbpro-20.04
I had an older version of Manjaro-ARM-Xfce on my emmc. Had no trouble installing it to the emmc thanks to the
emmc-installers I found @ Manjaro. Now I wanted to do a clean install of Manjaro-ARM-kde-plasma-pbpro-20.04. I tried the Write-to-eMMC-version of it,
but the Pinebook simply refused to boot after inserting the sd card. (The on light was green but the display empty for a considerable period before I gave up). I decided that I might as well go the direct way and flashed Manjaro-ARM-kde-plasma-pbpro-20.04.img on the eMMC with the eMMC-USB-Connector and dd.
After starting the pinebook on led goes green, but the display remains empty. How do I go from here? Shouldnt reflashing the eMMC turn back the clock and give me a clean
system? Should I try another image and possible another tool than dd to write the image to the eMMC. How long should the initial boot last, meaning how long do I have to wait
with Manjaro KDE Plasma until something appears on the screen for the first time. Is 20.04 considered stable?
Yours sincerely
Stefan
Do you press Esc key to enter installer after boot?
Instructions are here https://forum.manjaro.org/t/manjaro-arm-...sed/133374
To use these images:
Download the eMMC Installer image of your choice.
Flash it to an SD card.
Boot the SD card on the device.
When the Manjaro logo has been present for about 15 seconds, press ESC (this is a bug, we know).
Follow the instructions on the screen.
(05-22-2020, 03:49 PM)erchache2000 Wrote: Do you press Esc key to enter installer after boot?
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,302 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 8 17,966 06-26-2025, 09:20 PM
Last Post: reukiodo
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 5,848 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 6,967 02-19-2025, 12:49 PM
Last Post: zkajdan
  Doing a fresh install docFarto 5 6,521 02-09-2025, 02:58 PM
Last Post: mikehenson
  Attempting to install Void Linux, boots into a black screen 9a3eedi 1 6,574 09-28-2024, 09:23 AM
Last Post: throwawayforvoid
  Manjaro Sway Theme Broken Eighty8 1 3,922 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 6,426 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 3,797 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 9,950 12-13-2023, 07:22 PM
Last Post: trillobite
