Flash to eMMC?
Is it possible to flash an image to eMMC without having to remove the module? Does Tow-Boot have any functionality that would help here?
(04-27-2022, 12:35 PM)Barugon Wrote: Is it possible to flash an image to eMMC without having to remove the module? Does Tow-Boot have any functionality that would help here?
No problem - just do it from an SDcard. You need to disable the eMMC during initial boot phase if it has something bootable on it as per the wiki.
(04-27-2022, 01:29 PM)dukla2000 Wrote: No problem - just do it from an SDcard. You need to disable the eMMC during initial boot phase if it has something bootable on it as per the wiki.
So, I would need a bootable OS on the SD in order to DD to eMMC.
Yes
for some reason my reply has to be longer than 3 chars before it will post
I'm using this case and I would need to extract the board from it in order to press that button anyway, so I guess removing the eMMC is the more straightforward approach.
  Can i use this Emmc for Rockpro 64 Supratec 2 5,357 12-20-2023, 09:12 AM
  eMMC modules ajtravis 3 6,545 10-12-2022, 01:44 PM
Last Post: ajtravis
  Installation Debian on emmc: which U-Boot and where? vongillus 3 8,215 07-02-2022, 09:24 AM
Last Post: dkebler
  rockpro64 emmc GreyLinux 8 14,990 11-08-2021, 01:56 PM
Last Post: GreyLinux
  eMMC 128gb flailingeffort 1 4,759 01-18-2021, 04:42 AM
Last Post: Wizzard
  RockPro64 eMMC boot euu 4 12,149 08-24-2020, 11:07 PM
Last Post: t4_4t
  sw4 jumper for disabling eMMC boot / multiboot ChriChri 0 3,986 03-09-2020, 08:54 AM
Last Post: ChriChri
  Availability of 128GB eMMC ? Arwen 1 5,125 07-22-2019, 11:28 AM
Last Post: Arwen
  board not working with EMMC RockPro64Newbie 1 4,869 05-10-2019, 02:22 AM
Last Post: Unkn0wn
  EMMC not booting while SD does. Apokalypz 29 54,393 03-10-2019, 04:12 AM
Last Post: graham-r
