I have a manjaro 20.03 install from march, now pacman does not work
I installed manjaro 20.03 in march, and pretty much haven't touched the pinebook since april. Now I am back to it, every time I try to run pacman it can't connect to the package servers.
Is there any way of fixing this? Or will I have to completely reinstall to a newer manjaro? I just want to install a few more packages and update what I have.
I get this output:
:: Synchronising package databases...
error: failed retrieving file 'core.db' from manjaroarm.mirrors.lavatech.top : Could not resolve host: manjaroarm.mirrors.lavatech.top
core is up to date
error: failed retrieving file 'extra.db' from manjaroarm.mirrors.lavatech.top : Could not resolve host: manjaroarm.mirrors.lavatech.top
extra is up to date
error: failed retrieving file 'community.db' from manjaroarm.mirrors.lavatech.top : Could not resolve host: manjaroarm.mirrors.lavatech.top
community is up to date
:: Starting full system upgrade...
there is nothing to do
Read this: https://forum.manjaro.org/t/another-mirr...red/132302
(08-14-2020, 07:16 AM)Ilia3101 Wrote: I installed manjaro 20.03 in march, and pretty much haven't touched the pinebook since april. Now I am back to it, every time I try to run pacman it can't connect to the package servers.
I get this output:
core is up to date
extra is up to date
Maybe try $ sudo pacman-mirrors -f 5
Cheers!
This is from 4+ months ago...
and if you get
error: failed to commit transaction (conflicting files)
nss: /usr/lib/p11-kit-trust.so exists in filesystem
either use --force-overwrite or mv that file to /usr/........bak
Thank you everyone!
Changing the mirrorlist file fixed everything, no extra steps were required, full system upgrade successful.
I'm guessing this is a question that's been asked millions of times before. Sorry for filling up the forum Blush
(08-14-2020, 05:14 PM)Ilia3101 Wrote: Thank you everyone!
 Manjaro 20.04 is a big upgrade and needs to perform a fresh install.
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,048 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 8 17,395 06-26-2025, 09:20 PM
Last Post: reukiodo
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 5,500 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 6,549 02-19-2025, 12:49 PM
Last Post: zkajdan
  Doing a fresh install docFarto 5 6,201 02-09-2025, 02:58 PM
Last Post: mikehenson
  Attempting to install Void Linux, boots into a black screen 9a3eedi 1 6,315 09-28-2024, 09:23 AM
Last Post: throwawayforvoid
  Manjaro Sway Theme Broken Eighty8 1 3,823 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 6,295 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 3,625 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 9,604 12-13-2023, 07:22 PM
Last Post: trillobite
