Steps to install latest debian img to upgraded emmc
I just installed the 128G module which comes with android 7.1.2 installed on it (not sure why). Anyway, I've been reading through the threads about how the new factory image is available which is great. Here's what happened.
1. booted to the SD but the power light just flashed. Nothing from there.  Huh
2. flipped the onboard switch to disable the eMMC.
3. booted from SD.  Big Grin
4. flipped the onboard switch to enable the eMMC.
5. looked to see if the eMMC was available but no dice.  Confused
6. rebooted and ended up back at step 1.  Angry
7. Reaching out for help  Blush
While I'm writing this, I'm flashing the latest build to a USB to see if I can go that route. If this proves to be successful, what are the steps I need to take to dd the image to the eMMC? I am a noob but not afraid of the command line.
Thanks in advance.
Steps to install latest debian img to upgraded emmc - by xircledev - 11-29-2019, 10:38 PM
  Debian on Pinebook Pro u974615 7 1,381 03-31-2024, 10:11 AM
Last Post: u974615
  Attempting to install Void Linux, boots into a black screen 9a3eedi 0 398 02-18-2024, 08:54 AM
Last Post: 9a3eedi
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,250 12-13-2023, 07:22 PM
Last Post: trillobite
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 464 12-07-2023, 03:11 PM
  install debian on pbp jsch 7 4,184 11-22-2023, 04:22 PM
Last Post: TRS-80
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,674 09-07-2023, 09:38 PM
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 2,036 08-21-2023, 09:08 PM
Last Post: vanessadonald
  Install deepin OS on pinebook pro wangyukunshan 4 1,677 08-07-2023, 01:12 PM
Last Post: myself600
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 7 4,192 07-15-2023, 02:58 PM
Last Post: u974615
  Blank screen after Armbian 20.04 install to emmc? psychoacoustic 3 3,584 04-01-2023, 03:22 PM
Last Post: TRS-80
