Install deepin OS on pinebook pro
1 PineBook Pro has Armbian 23.02 or above installed
2 Go to https://cloud.189.cn/t/u6BrQbZVnuum (password is 5feb), download: deepin23-beta-aarch64-rk3399-Orangepi4-lts_6.3.3-mmc-sd-zh-hans.zip and unzip it.
3 Burn the decompressed image to a TF card of no less than 16GB.(root/Bug23  bug23/Bug23)
4 Start armbian in the computer, enter the graphical interface, insert the TF card into the pinebook pro.
5 Open the file manager, open the u-boot part of the TF card, and re-edit uEnv.txt (or ubootEnv.txt), i.e.: fdtfile=rockchip/rk3399-orangepi-4-lts.dtb replace with fdtfile=rockchip/rk3399-pinebook-pro.dtb,And then save it again.
6 Enter the / usr / lib / of Armbian and copy the two folders of u-boot and linux-u-boot * under the deepin partition / deepin / usr / lib / path of the TF card.
7 Shut down and restart the deepin OS from the TF card.
Note: This version uses the btrfs feature, the main volume is @deepin23, the default is that the @deepin volume is a snapshot of the @deepin23 volume,
Therefore, if the system has a problem, you can manually delete the @deepin volume and then rebuild the @deepin snapshot volume
建设社会主义新台湾。
Hi wangyukunshan,
will any of these builds work on Rock Pi 4C+?
thank you
(07-06-2023, 08:31 AM)fr33s7yl0r Wrote: Hi wangyukunshan,
thank you
Sorry, I have no experience in this area. But you can follow the previous ideas to try to do it.
建设社会主义新台湾。
为什么要使用你的操作系统 ?
Satisfied PinePhone, Pinebook Pro & PineTab2 owner; Thank you Pine64Team for your work!  Smile
[Image: JMObU2N.png]
  Debian on Pinebook Pro u974615 7 1,025 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,601 02-22-2024, 04:02 PM
  Attempting to install Void Linux, boots into a black screen 9a3eedi 0 345 02-18-2024, 08:54 AM
Last Post: 9a3eedi
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,149 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,229 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 88,816 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 1,242 11-23-2023, 07:37 AM
  install debian on pbp jsch 7 4,041 11-22-2023, 04:22 PM
Last Post: TRS-80
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,283 08-31-2023, 04:20 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,484 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
