Attempting to install Void Linux, boots into a black screen
I decided to replace Manjaro on my PBP and try out Void Linux. I never used it before, but would like to see how well it works with musl on the pinebook pro, since Manjaro felt a little heavy on it. I followed the instructions here, https://wiki.pine64.org/wiki/Pinebook_Pr..._Linux_ARM, with the following notes:
  • I used a Manjaro live environment to do the configuration, and I booted the live environment from an SD card
  • I first followed the Arch tutorial to flash Tow-Boot and create the partitions. I used ext4 for both the boot and root partitions.
  • I then extracted the void rootfs into the root partition, then chrooted into it, and started following the void tutorial located here while avoiding any boot-loader related instructions. I updated xbps and installed base-system and also set the root password. I did not install grub because I figured Tow-Boot woudl be doing the booting
  • I installed the pinebookpro-kernel package with xbps because I didn't want to build my own kernel.
  • I installed the u-boot-menu
  • Despite what the instructions said, I had to write my own extlinux.conf and I made sure to point to the right kernel file, and that fdt points to the right file
Now when I boot from eMMC with Tow-Boot, I get some garbled video, and then it's a black screen, so I can't really tell what's going on. I feel like I'm getting really close, but I'm not sure what I did wrong. Can anyone help?
  install debian on pbp jsch 7 4,039 11-22-2023, 04:22 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,482 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Install deepin OS on pinebook pro wangyukunshan 4 1,585 08-07-2023, 01:12 PM
Last Post: myself600
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 7 4,058 07-15-2023, 02:58 PM
Last Post: u974615
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 660 07-13-2023, 05:21 PM
Last Post: owaspfap
  Kali Linux for Pinebook Pro Luke 100 159,532 05-03-2023, 06:10 AM
Last Post: dachalife
  Blank screen after Armbian 20.04 install to emmc? psychoacoustic 3 3,499 04-01-2023, 03:22 PM
Last Post: TRS-80
Rainbow How to prevent the screen from dimming (no X/wm/desktop)? cowsay 0 541 02-16-2023, 10:58 AM
Last Post: cowsay
  unsuccessful re-install of OS for PineBookPro Valiance 3 1,309 02-14-2023, 12:49 PM
Last Post: Valiance
  DiY - Installing Void Linux ARM On The Pinebook Pro vincele 1 1,204 11-28-2022, 05:03 PM
