Blank screen after Armbian 20.04 install to emmc?
I've been using Manjaro on my PBP, but coming from a Ubuntu background decided to give Armbian a try. I managed to first install Armbian Focal (directly from armbian.com) first on a USB thumbdrive, then from emmc, both successful - but then I decided try Armbian Hirsuite directly on emmc. I booted from the USB drive (Armbian Focal) and wrote the (unxz'd) image to /dev/mmcblk2 (only mmcblk device).
And now it doesn't boot. Here's the weird thing: I don't even see the usual Uboot messages flash by... did I manage to break it somehow? I thought writing to /dev/mmcblkX (no suffix) would write only to the "user" part.
The PBP doesn't change it's behaviour if I try booting off the USB thumbdrive. That drive is unchanged from the time I did the write to emmc, so it should be good in theory.
The power LED does indicate something is happening, luckily. From the (presumed) off state, pressing the power button a few seconds turns the LED on, first red, then shortly after green. If I tap the power button again a bit after, the LED goes off again after a short delay.
Any advice? If I can fix this without opening the case that'd be great, but I'm not too afraid to open it up either, and can wire myself a UART adapter if I have to (Waveshare CP2102 board, I just need to find a spare 3.5mm stereo jack in my parts bin). Or would even be pushing the reset button suffice?
Thank you for any hints!
Nearly always, an image will have a uboot package in the 1st 16M... so you likely have a new uboot
If you run fdisk on the uncompressed image, it will show 1st partition
starts at 32768 (sectors) or 62500 (manjaro)
The extra space for manjaro,, maybe they are thinking ahead, an ESP partition???
There is always an idbloader at 64 sectors, then a uboot.idb OR uboot.img and trust.img
(Uboot at 8M , if trust at 12M)
Try to see if it boots from sd? Otherwise, disable emmc, will NOT boot from usb with no working uboot
I think (not 100% sure) that a long pwr button press (20+ sec) equal reset button
This might help, clears out some residual configs that may be bad
Or, maybe not
(10-13-2021, 12:43 PM)wdt Wrote: Nearly always, an image will have a uboot package in the 1st 16M... so you likely have a new uboot
Or, maybe not
Thank you, that worked! I wrote a fresh Manjaro (Sway) image onto a SD card, but it wouldn't just boot from it (20s pressing the power button did not help) - I did have to open up the PBP to flip the "disable booting from emmc"  switch. It then booted from SD, and can also boot from USB if the SD card is present.
Again, thanks! I'll be a bit more careful writing images to emmc from now on...
If you are still interested in Armbian, I recently got it working (via SD card and/or eMMC) here.
Cheers,
TRS-80
Protocols, not Platforms
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 4,650 08-09-2025, 06:53 AM
Last Post: Sb2024
  Armbian fix, current version now works Sb2024 0 573 08-08-2025, 08:49 AM
Last Post: Sb2024
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 8 9,058 06-26-2025, 09:20 PM
Last Post: reukiodo
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 2,362 02-19-2025, 12:49 PM
Last Post: zkajdan
  Doing a fresh install docFarto 5 2,226 02-09-2025, 02:58 PM
Last Post: mikehenson
  Attempting to install Void Linux, boots into a black screen 9a3eedi 1 2,988 09-28-2024, 09:23 AM
Last Post: throwawayforvoid
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 1,637 05-31-2024, 09:42 AM
Last Post: SynthGal
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 5,500 12-13-2023, 07:22 PM
Last Post: trillobite
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 1,824 12-07-2023, 03:11 PM
  install debian on pbp jsch 7 7,832 11-22-2023, 04:22 PM
Last Post: TRS-80
