Manjaro 20.04 not loading from SD (with Manjaro on eMMC)
I have Manjaro installed on the eMMC.  I used the Manjaro-ARM-xfce-pbpro-20.04-emmc-installer-20.04.img from OSDN, and then updated it.
Since then I've been able to try various operating systems on SD (eg. Ubuntu, Debian), but I can't seem to run Manjaro-ARM-xfce-pbpro-20.04.img from SD.
It's not simply that they are both Manjaro.  Manjaro-ARM-gnome-pbpro-23.02.img on SD loads.
Is there a way I can get Manjaro-ARM-xfce-pbpro-20.04.img to load without opening the computer and physically switching off the eMMC?
When I try to run Manjaro-ARM-xfce-pbpro-20.04.img off SD, the computer runs Manjaro off the eMMC and the SD shows as an external drive.
The reasons I want to run Manjaro-ARM-xfce-pbpro-20.04.img from SD is so I can update and configure it so I have back up in case the eMMC fails, and also have system where I can try things without breaking the OS on eMMC.
(Using Manjaro-ARM-xfce-pbpro-23.02.img from Manjaro's site instead wouldn't work because HDMI via USB-C only seems to work with the OSDN images.)
Any ideas?
Try .... sudo blkid ,, is the fs labels duplicated? Also cat /etc/fstab
IIRR manjaro uses fslabels in fstab
So, change labels on sd, add "-sd" suffix, edit fstab and maybe extlinux.conf
  Manjaro Sway Theme Broken Eighty8 1 282 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,759 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 331 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,143 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,229 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 895 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,022 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,974 08-21-2023, 09:08 PM
  Manjaro - HIbernate - brcmfmac clk issue pompeyPinePro 1 767 08-18-2023, 02:06 AM
Last Post: juliamenendez
  Issue with booting Manjaro from encrypted NVMe drive on pbp Cs137 1 972 08-18-2023, 01:58 AM
