Manjaro with Full Disk Encryption and GRUB
Question
Hi folks! I have a working install of Manjaro Sway on eMMC (and Tow-Boot on SPI), and want to 'reform' it into a setup with full FDE (as much as possible). To do this, I did the following so far:
  • Created a USB drive with one ESP and one LUKS partition
  • Created LVM swap and root partitions inside LUKS volume
  • Copied working system from eMMC to USB drive
  • Used manjaro-chroot to install GRUB
This USB drive can now boot from GRUB, and prompts for the LUKS password. After entering it, it takes about 3 minutes to unlock the key, then drops me at the GRUB prompt. It appears that there are no menu entries at all.
Any ideas on how to continue? And on a related note, any ideas on how to speed up the cores in GRUB so that it unlocks the key faster?
(02-11-2022, 04:21 PM)dumetrulo Wrote: Hi folks! I have a working install of Manjaro Sway on eMMC (and Tow-Boot on SPI), and want to 'reform' it into a setup with full FDE (as much as possible). To do this, I did the following so far:
I think  if you have a TPM (Trusted Platform Module) chip on your system, you might be able to configure it to store the encryption key, which can speed up the unlocking process.
  Manjaro Sway Theme Broken Eighty8 1 273 03-08-2024, 08:41 AM
  Manjaro network problem late 2023 acruhl 1 320 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,125 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,186 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 400 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 873 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,016 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,963 08-21-2023, 09:08 PM
  Manjaro - HIbernate - brcmfmac clk issue pompeyPinePro 1 759 08-18-2023, 02:06 AM
Last Post: juliamenendez
  Issue with booting Manjaro from encrypted NVMe drive on pbp Cs137 1 964 08-18-2023, 01:58 AM
