install debian on pbp
Hello
I would like to create a how-to file. If there is a usb-ethernet adapter available, then the steps could look like this:
source files
bullseye
wget http://http.us.debian.org/debian/dists/bullseye/main/installer-arm64/current/images/netboot/SD-card-images/firmware.pinebook-pro-rk3399.img.gz
wget http://http.us.debian.org/debian/dists/bullseye/main/installer-arm64/current/images/netboot/SD-card-images/partition.img.gz
bookworm
wget http://http.us.debian.org/debian/dists/bookworm/main/installer-arm64/current/images/netboot/SD-card-images/firmware.pinebook-pro-rk3399.img.gz
wget http://http.us.debian.org/debian/dists/bookworm/main/installer-arm64/current/images/netboot/SD-card-images/partition.img.gz
create img file
zcat firmware.pinebook-pro-rk3399.img.gz partition.img.gz  > complete_pbp_image.img
write installer on micro-SD
identify device name of micro-SD
lsblk
NAME   MAJ:MIN RM   SIZE RO TYPE MOUNTPOINTS
sdd      8:48   1   7.4G  0 disk
└─sdd1   8:49   1 130.5M  0 part
write to micro-SD
sudo dd if=complete_pbp_image.img of=/dev/sdd bs=4k status=progress oflag=sync
boot pbp from micro-SD
boot and install on eMMC
firmware
add non-free
sudo sed --in-place -e 's/ main$/ main non-free/' /etc/apt/sources.list
install
sudo apt-get update
sudo apt-get install firmware-brcm80211 firmware-misc-nonfree raspi-firmware
  • firmware-brcm80211 holds some wifi firmware -- is this required?
  • raspi-firmware holds brcmfmac43456-sdio.bin
  • firmware-misc-nonfree holds rockchip firmware
If no usb-ethernet adapter is available, what are the necessary steps?
Would it suffice to download them, copy them to an usb stick and mount the latter on pbp?
I've been just chroot-ing in and installing additional packages.
As an aside, the raspi-firmware package causes all sorts of errors in `apt` once it is installed - I've been skipping these firmware installs and simply copying firmware I found in a Kali Linux support thread to the correct location, which appears to get WiFi & bluetooth functioning perfect!
https://gitlab.com/kalilinux/build-scrip...1069959116
(06-19-2022, 02:29 AM)jsch Wrote: Hello
source files
bullseye
bookworm
create img file
lsblk
write to micro-SD
firmware
add non-free
install
sudo apt-get update
Cool: I just ordered mine Pro, in the meanwhile I am playing with Manjaro xfce in my Linux Box: By the moment I prefer Debian. I will follow your post here to install Debian once my Pro will arrive.
Thank you so much for writing this. It really helped.
I have found, though, that installing 'firmware-misc-nonfree' breaks suspend on my Pinebook Pro. Have you noticed that? Suspend works fine without installing it and everything else seems to be working fine without it as well.
Thank you so much for writing this. It really helped with my installation.
I did find, however, that installing 'firmware-misc-nonfree' broke suspend on my Pinebook Pro. After installing the package, it seemed like the PBP could go to sleep but wouldn't wake up and I'd have to do a hard shutdown to recover. Have you noticed that?
Without installing the package, everything appears to work as expected including suspend/wake.
It says here https://wiki.pine64.org/wiki/Pinebook_Pr...ses#Debian
"Installer currently doesn't install a functional bootloader, leaving the installed system in an unbootable state until it's manually added"
is this still true?
Armbian is a lot easier, and takes care of a lot of kernel patching and other issues which are particular to specific hardware.  They are far ahead of upstream Debian, at least on SBCs, which is their raison d'être, after all
Cheers,
TRS-80
Protocols, not Platforms
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 8 16,513 06-26-2025, 09:20 PM
Last Post: reukiodo
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 5,892 02-19-2025, 12:49 PM
Last Post: zkajdan
  Doing a fresh install docFarto 5 5,796 02-09-2025, 02:58 PM
Last Post: mikehenson
  Attempting to install Void Linux, boots into a black screen 9a3eedi 1 5,898 09-28-2024, 09:23 AM
Last Post: throwawayforvoid
  Official Debian support moonwalkers 64 111,943 07-08-2024, 01:40 PM
Last Post: Humid Stylus
  Debian on Pinebook Pro u974615 7 10,775 03-31-2024, 10:11 AM
Last Post: u974615
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 20,742 09-07-2023, 09:38 PM
  Install deepin OS on pinebook pro wangyukunshan 4 6,111 08-07-2023, 01:12 PM
Last Post: myself600
  Blank screen after Armbian 20.04 install to emmc? psychoacoustic 3 8,960 04-01-2023, 03:22 PM
Last Post: TRS-80
  unsuccessful re-install of OS for PineBookPro Valiance 3 4,689 02-14-2023, 12:49 PM
Last Post: Valiance
