Debian on Pinebook Pro
What is the state of USB Type C DiplayPort out on Debian 12 for the Pinebook Pro?  It seems like all the required kernel modules are loading, but it doesn't work.  Is this a Debian 12 kernel issue or a U-Boot Issue?
Do you have `firmware-misc-nonfree` installed?
Yes.
firmware-misc-nonfree is already the newest version (20230210-5).
If you run `dmidecode`, does it tell you what u-boot version you're using?
Can you try a Stable-backports kernel and see if that changes/improves the situation (currently version 6.6.13-1~bpo12+1) ?
# dmidecode 3.4
# No SMBIOS nor DMI entry point found, sorry
$ uname -r
Linux PinebookPro 6.1.0-18-arm64 #1 SMP Debian 6.1.76-1 ( 2024-02-01) aarch64 GNU/Linux
Is the correct backport repo "http://deb.debian.org/debian bookworm-backports main contrib non-free non-free-firmware" ?
"typec_displayport" is the correct Linux kernel module to have loaded?
(03-22-2024, 09:46 AM)u974615 Wrote: # dmidecode 3.4
Bummer
Quote:$ uname -r
Linux PinebookPro 6.1.0-18-arm #1 SMP Debian 6.1.76-1 ( 2024-02-01) aarch64 GNU/Linux
Are you sure that isn't 6.1.0-18-arm64? Note the arm64 part.
Quote:Is the correct backport repo "http://deb.debian.org/debian main contrib non-free non-free-firmware" ?
No, that's the normal repo. For backports see here: https://backports.debian.org/Instructions/
(03-22-2024, 10:58 AM)u974615 Wrote: "typec_displayport" is the correct Linux kernel module to have loaded?
I think so, but I don't know.
USB Type C Alternate Mode DisplayPort out on the PineBook Pro doesn't even work with the PINE64 Dock.
I gather that USB Type C Alternate Mode Displayport out is no longer supported in Debian Workstation 12 aarch64, at least for the PineBook Pro.
I imagine the backstory as to why it was demonstrated to work and why it doesn't now would be intriguing. Of course the demos I saw were for Manjaro and not Debian and wasn't using Tow-Boot.
I can see that this is a difficult feature to do. Google can't even get it to work on the Pixel Phone and Pixel Tablet. Whereas Samsung Galaxy phones have had it for years.
  Pinebook Pro upgrading from the factory image yamsoup 12 1,603 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,149 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,230 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 88,820 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 1,244 11-23-2023, 07:37 AM
  install debian on pbp jsch 7 4,041 11-22-2023, 04:22 PM
Last Post: TRS-80
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,429 09-07-2023, 09:38 PM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,283 08-31-2023, 04:20 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,486 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Install deepin OS on pinebook pro wangyukunshan 4 1,586 08-07-2023, 01:12 PM
Last Post: myself600
