How to prevent the screen from dimming (no X/wm/desktop)?
Rainbow
Hey. I'm playing around with some stuff on my pinebook and I've noticed that if I'm in a tty, or don't even have X installed at all, the screen still dims after a few minutes regardless of whether or not I'm plugged into power.  I will just be sitting at a command line typing something and the screen goes dark.
/sys/class/backlight/edp-backlight/brightness changes from 4096 to 2047.
If not X, what is controlling this and how do I prevent it?  Is there a kernel setting I can configure or something?
I also don't want to force max brightness 100% of the time, I would still like to be able to control brightness manually
Thank you Smile
  Attempting to install Void Linux, boots into a black screen 9a3eedi 0 345 02-18-2024, 08:54 AM
Last Post: 9a3eedi
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 664 07-13-2023, 05:21 PM
Last Post: owaspfap
  Blank screen after Armbian 20.04 install to emmc? psychoacoustic 3 3,499 04-01-2023, 03:22 PM
Last Post: TRS-80
  when i close my laptop lid the screen doesn't turn on? (debian bullseye based) computerc 3 1,902 09-23-2022, 08:37 PM
Last Post: computerc
  How do I change screen brightness in Dietpi computerc 2 1,609 07-15-2022, 07:59 PM
  Install the DDE desktop environment wangyukunshan 0 1,332 12-23-2021, 06:51 PM
Last Post: wangyukunshan
  Desktop environment of Ubuntukylin 20.04 wangyukunshan 3 3,208 10-26-2021, 08:07 PM
  Adjusting screen resolution lead to a black screen Linux-Rob 28 26,655 06-27-2021, 02:12 AM
Last Post: Arwen
  Manjaro Issues: Dark Screen & Font size Sally2 1 3,004 12-19-2020, 03:33 PM
Last Post: wove
  dim screen after kernel upgrade bsammon 5 6,736 11-17-2020, 08:50 PM
Last Post: xyzzy
