Kali Linux for Pinebook Pro - stuck on the login screen
Hi everyone,
I want to be able to run kali off of the pinebook pro as needed via the SD card. I followed the Pinebook Pro installation instructions here: https://www.kali.org/docs/arm/pinebook/
* Download and validate the kali linux image
* flash the kali-linux-2023.2-pinebook-pro-arm64.img file to the SD card (note, no errors or issues took place on flashing the SD card)
* insert the SD card to the pinebook pro
* start the machine
From here, I'll see what appears to be the boot process loading which is a wall of text. Note that I saw several "FAILED" "Failed to start ssh.service - OpenBSD SecureShell error, etc.
kali-pinebook-pro login:
password:
After the booting process stops, I am dropped into a CLI login screen. I attempt to use the kali login defaults e.g. username: kali and password kali which shows as invalid. Does anyone have the default login and password or can we determine if I did something horribly wrong?
Thank you!
  Debian on Pinebook Pro u974615 7 1,025 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,601 02-22-2024, 04:02 PM
  Attempting to install Void Linux, boots into a black screen 9a3eedi 0 345 02-18-2024, 08:54 AM
Last Post: 9a3eedi
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,149 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,229 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 88,816 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 1,242 11-23-2023, 07:37 AM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,283 08-31-2023, 04:20 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,484 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Install deepin OS on pinebook pro wangyukunshan 4 1,586 08-07-2023, 01:12 PM
Last Post: myself600
