Does anyone know if it is possible to install a devuan gnu/linux ?
I get a bit lost with architecture, I can't find image for pinebook pro.
You know if you can install a devuan. You know freedom software
Without systemd 8=]
a greeting
Idk about devuan. Probably more luck with artix linux (manjaro openrc's successor) since it is more active.
(10-10-2019, 11:48 AM)erosketak Wrote: I get a bit lost with architecture, I can't find image for pinebook pro.
Without systemd 8=]
a greeting
If you are only interested in the systemd aspect, then you are lucky. The preinstalled OS is Debian 9. I don't know about Debian 10, but it's quite easy to run Debian 9 without systemd. Just uninstall it and apt-get automatically pulls in sys-v. The only remains is the systemd shim layer libsystemd0.
On my intel laptop, I run Debian 9 with sys-v and it works like a charm. I expect this to be true for the Pinebook Pro, although I have not tried it.
Has anyone had any luck with Artix on the PBP?
Short answer: yes. There's a thread in the tutorial section of this forum (and actually, a number of them across the web) explaining how to convert a Debian install into Devuan. I've done it successfully with the original (Mr Fixit) Debian image, but don't see why it wouldn't work with a newer build.
You can simply Replace systemd as your init system and leave systemd in place to appease app dependencies (apt-get install sysvinit-core sysv-rc-conf - this automatically de-installs systemd-sysv. I believe this is basically what MX-Linux does). Or you can wipe systemd completely and switch to the Devuan repositories (this is a bit more involved. Best to read through the tutorials)
hack danielt's debian installer and use a devuan debootstrap instead.
  Can’t login to Linux fnosai 0 3,329 07-27-2025, 12:30 AM
Last Post: fnosai
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 8 18,760 06-26-2025, 09:20 PM
Last Post: reukiodo
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,367 02-19-2025, 12:49 PM
Last Post: zkajdan
  Doing a fresh install docFarto 5 7,071 02-09-2025, 02:58 PM
Last Post: mikehenson
  Void Linux: missing firmware from pinebookpro-firmware? remph 0 3,372 12-15-2024, 01:58 PM
Last Post: remph
  Attempting to install Void Linux, boots into a black screen 9a3eedi 1 6,897 09-28-2024, 09:23 AM
Last Post: throwawayforvoid
  Slackware Linux working on PBP vxzero 0 4,038 06-05-2024, 04:30 PM
Last Post: vxzero
  install debian on pbp jsch 7 12,311 11-22-2023, 04:22 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 7,432 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Install deepin OS on pinebook pro wangyukunshan 4 6,813 08-07-2023, 01:12 PM
Last Post: myself600
