Possible to install KDE Neon on PinebookPro?
I'm looking at buying a new laptop and I've got my eye on a PinebookPro. Can I install KDE Neon on it?
Cheers.
(10-13-2020, 07:25 PM)Pinoideae Wrote: I'm looking at buying a new laptop and I've got my eye on a PinebookPro. Can I install KDE Neon on it?
Cheers.
I've not seen a KDE Neon release for the Pinebook Pro, only for the older (less powerful) Pinebook.
A64, SOPINE, Rock64, RockPro64, Pinebook1080p, Pinebook Pro, Pinephone, Pinewatch dev kit, Pinetab, Pinecil, Pinenut, Quartz64, Pinephone Pro, and PineNote (so far)
Will try it today and then will take a feedback. It worked with previous Bionic release, so trying with Focal now.
(10-24-2020, 12:06 PM)Wizzard Wrote: Will try it today and then will take a feedback. It worked with previous Bionic release, so trying with Focal now.
Thanks.
Nice
Sent from my OnePlus 7 Pro using Tapatalk
I tried it, but was not able to install those NEON repo. Seems like some dependency problems.
(10-26-2020, 02:04 AM)Wizzard Wrote: I tried it, but was not able to install those NEON repo. Seems like some dependency problems.
Pity, but good to know. Thanks for reporting back.
If You install Manjaro for the PineBook PRO You will have the newest possible AARCH64 (ARM) KDE desktop You can have
It does not call itself  "Neon" but I see nor differences in build state
The problem why the latest NEON cannot be installed to PBP, is that it does not support ARM64, only ARMHF architecture.
The older NEON supported ARM64 too, I dont know why they dropped support for ARM64 in the current NEON.
(10-26-2020, 07:13 AM)Wizzard Wrote: The problem why the latest NEON cannot be installed to PBP, is that it does not support ARM64, only ARMHF architecture.
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 8 18,218 06-26-2025, 09:20 PM
Last Post: reukiodo
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,102 02-19-2025, 12:49 PM
Last Post: zkajdan
  Doing a fresh install docFarto 5 6,749 02-09-2025, 02:58 PM
Last Post: mikehenson
  Void Linux: missing firmware from pinebookpro-firmware? remph 0 3,257 12-15-2024, 01:58 PM
Last Post: remph
  Attempting to install Void Linux, boots into a black screen 9a3eedi 1 6,660 09-28-2024, 09:23 AM
Last Post: throwawayforvoid
  install debian on pbp jsch 7 12,038 11-22-2023, 04:22 PM
Last Post: TRS-80
  Install deepin OS on pinebook pro wangyukunshan 4 6,665 08-07-2023, 01:12 PM
Last Post: myself600
  Blank screen after Armbian 20.04 install to emmc? psychoacoustic 3 9,431 04-01-2023, 03:22 PM
Last Post: TRS-80
  unsuccessful re-install of OS for PineBookPro Valiance 3 5,091 02-14-2023, 12:49 PM
Last Post: Valiance
  Tow Boot install help Paulie420 7 11,047 11-24-2022, 10:24 AM
