U-Boot with direct NVMe boot support for eMMC/SPI Flash
#61
i still have the bootloader on emmc, and /boot and root on nvme. looking at this again to flash SPI for nvme-only boot.
what is the process to create the spiflash.bin from these sources? as mrfixit accepted pcm's pcie PR, the v2.0 branch is more featureful.
and is anyone tracking the status of mainline u-boot?
wondering if these topics/threads can be expanded upon definitively.
Check this out:  I must have lucked out and installed this before NVME booting was disabled,  but I have been booting the NVME since February.   He @"dhivael"
https://forum.pine64.org/showthread.php?tid=8752  (original thread)    I believe Manjaro at one time was using that u-boot  .  I can boot from NVME, SD, and EMMC for sure,  I don't remember trying a USB boot.
He also explains in the git how to build the binaries to be flashed.
https://git.eno.space/pbp-uboot.git/
Also see this thread:  https://forum.pine64.org/showthread.php?tid=8685  From @sigmaris .  I have been using his uboot on SPI flash on a rockpro64.  He has made it very easy to flash/erase SPI whitout going into maskrom mode to install it.
I haven't a chance to check out the current state of  the latest  Mainline u-boot recently.
I am relatively new to the linux world:  I think if you take a look at these threads you could figure out what you want to do...
FWIW
thanks. i am aware of the great resources of how to flash the SPI and where to download it. i am specifically asking two questions that i did not see addressed:
how do you create the SPI image?
is anyone tracking mainline uboot and can compare features to mrfixit v2.0 uboot?
i found an answer to the first question in the repo you linked:
https://git.eno.space/pbp-uboot.git/comm...c497d62ac5
(06-28-2020, 11:40 AM)xmixahlx Wrote: thanks. i am aware of the great resources of how to flash the SPI and where to download it. i am specifically asking two questions that i did not see addressed:
Hi!
Just yesterday I updated my build script to build from upstream U-Boot and reference ARM Trusted Firmware, no Rockchip blobs this time.
This one is based on patches from dhivael, sigmaris and Manjaro. The resulting SPI image works on my PBP and boots from NVMe just fine.
You can find it here:
https://github.com/pcm720/u-boot-build-scripts
thanks pcm!!! that is EXACTLY what i was looking for and will be incredibly helpful.
I'm still interested in this. I currently have the emmc as root and the nvme as home. Is this attainable for the average Joe (me)? Is there much benefit?
(07-07-2020, 02:54 AM)mamboman777 Wrote: I'm still interested in this.  I currently have the emmc as root and the nvme as home.  Is this attainable for the average Joe (me)? Is there much benefit?
Back up your data and give it a shot! The github page for pcm's BSP-based uboot has the terminal command for writing the a file to the SPI, and a few other users have added a wiki page with steps one can take to help recover a bad flash on SPI. Once you've got this uboot on SPI, you should able to install and boot directly from the NVMe, w/o splitting partitions among drives.
Thanks for the encouragement.  Making a backup now.
Just to be clear, you are saying I should follow instructions from this, right?  https://github.com/pcm720/u-boot-build-scripts
(07-07-2020, 08:35 AM)mamboman777 Wrote: Thanks for the encouragement.  Making a backup now.
No, his earlier, rockchip-based uboot has this command for writing to SPI:
sudo dd if=spiflash.bin of=/dev/mtd0
Looking at the build script of the most recent (your link,) that spiflash.bin will be in your build folder.
Ok.  Still seeking clarification as I'd really like this to work the first time.  1. Download and extract from https://github.com/pcm720/u-boot-build-scripts
2. Run build.sh
3. then run "sudo dd if=spiflash.bin of=/dev/mtd0
If this is already documented someplace, I apologize, but could you please point me in the right direction.
Thanks!
Sad What to can't boot from TF card, EMMC system broken - any advice?do guys? qingss0 1 984 12-18-2025, 01:05 AM
Last Post: qingss0
  swap eMMC advice jceaser 2 1,331 10-23-2025, 09:59 PM
  Need new eMMC Karsten1 2 3,385 10-23-2025, 09:38 AM
Last Post: jceaser
  Bonk to boot biketool 2 1,526 10-21-2025, 09:08 AM
  3 days in, slow/stuck or no boot. lgmpbp2 34 26,953 06-11-2025, 08:53 AM
Last Post: lgmpbp2
  upgrading u-boot--what version? where to get it? bsammon 14 16,862 04-03-2025, 07:47 AM
Last Post: Tazdevl
Tongue Yet another Pinebook Pro won't boot thread pinemouth 5 11,562 12-27-2024, 11:38 AM
Last Post: akash3995
  broken tow-boot hashkeeper 1 3,904 12-25-2024, 10:12 PM
Last Post: jessipinkman
  Cant boot into an OS trashtendenz 3 5,092 10-23-2024, 03:49 AM
Last Post: chaylengordon
  Unable to boot? YossiS 4 3,690 09-04-2024, 10:35 AM
