Need new eMMC
Hi guys,
I got my Pinebook Pro out of the cupboard again after a few years. Since the updates didn't go through, I decided to update it with a current Manjaro via the SSD card and then wanted to write the system to the eMMC.
It seemed as if everything had been transferred cleanly to the eMMC. Finally I entered "sync" and wanted to reboot.
Since then nothing works anymore. Pressing the start button shows no reaction. Even flipping the internal switch to start manually via the SD card was unsuccessful.
The system is completely dead.
A question for you: Is there anyone here who can reflash the eMMC for me? Or can I order an eMMC including operating system somewhere?
best regards
Karsten
Take the eMMC out for now. You're going to need to get a micro sD card to boot, which likely means zeroing the SPI nor ROM.
Every time I've ever tried to update arch (Manjaru) after a long period of no updating, it ends up "soft-bricked".
Until you have a working system, pressing the start button will not give you obvious results, unless you notice the temperature of the SOC. (Hot, running, cold, not running). The power light is software driven.
:wq
(07-22-2025, 03:10 PM)KC9UDX Wrote: Take the eMMC out for now.  You're going to need to get a micro sD card to boot, which likely means zeroing the SPI nor ROM.
I just did a bunch of this myself last month. I accidentally bricked the computer. My solution was to open up the computer, toggle the switch that changes the boot order, then I installed armbian from an sd card. None of this went as planned and I spent an entire day working with chatgpt to get the boot right because armbian messed that up. Eventually I got there and now the computer boots.
First note: if you do open the computer, go easy, the speakers are on the lid and I ripped one of the wires.
Second note: the AI is dumb as bricks, but if you ask the right questions you can get there.
I would give more details, but frankly it was a slog, mostly because armbian chocked on me. Maybe there was a different distro I could have used.
Sad What to can't boot from TF card, EMMC system broken - any advice?do guys? qingss0 1 1,990 12-18-2025, 01:05 AM
Last Post: qingss0
  swap eMMC advice jceaser 2 2,255 10-23-2025, 09:59 PM
  Happy eMMC and SDcard OS usage for Pinebook Pro Newbies... Paulie420 42 102,709 11-20-2023, 06:22 PM
  I'm booting from NVME but I want to switch back to eMMC acruhl 4 6,327 04-23-2023, 06:58 AM
Last Post: acruhl
  Doesn’t power on after flashing emmc badguru 3 5,239 02-25-2023, 09:00 PM
Last Post: badguru
  eMMC problem with Tow-Boot/u-boot on SPI repa 3 5,540 02-21-2023, 01:49 AM
Last Post: repa
  Partial boot after installing Manjaro on emmc regivanx 11 11,847 02-06-2023, 09:11 AM
  Unable to Boot anything (emmc or SDcard) line72 5 6,939 01-17-2023, 12:07 PM
Last Post: nfms
  What OS have you recently flashed onto PBP eMMC? jcun4128 6 7,272 11-26-2022, 09:39 AM
  Unable to boot from emmc after flashing it rfm83 3 6,069 11-08-2022, 10:59 PM
Last Post: rfm83
