Cant boot into an OS
Pinebook Pro did arrive today. When turning it on (battery fully charged) I was able to boot into Manjaro. When rebooting I had visual glitches and after the second reboot I wasnt able to boot anymore. Green LED turns on, Charging LED as well. No sign of any booting. Armbian flashed onto SDcard doesnt boot either with emmc turned both on and off.
Any help you can provide to get it running again.
I have no clue where to even really start
Kind regards
Unfortunately I don't have any links you can follow. But this site is full of examples of what you are describing, with solutions.
Manjaru comes with a version of U-Boot that doesn't want to boot anything but Manjaru. I presume it put that on the SPI ROM. But possibly you just have a non-bootable sd card.
If the green light comes on, it is surely booting. That LED is turned on by the operating system.
:wq
It sounds like your Pinebook Pro might be experiencing some issues related to the boot process.
eMMC Off, SD Card On: Try turning off the eMMC using the internal switch and boot from your SD card. Make sure the Armbian image you flashed is specifically for the Pinebook Pro. Sometimes an incorrect image can prevent booting.
Sad What to can't boot from TF card, EMMC system broken - any advice?do guys? qingss0 1 2,333 12-18-2025, 01:05 AM
Last Post: qingss0
  Bonk to boot biketool 2 2,964 10-21-2025, 09:08 AM
  3 days in, slow/stuck or no boot. lgmpbp2 34 33,446 06-11-2025, 08:53 AM
Last Post: lgmpbp2
  upgrading u-boot--what version? where to get it? bsammon 14 20,570 04-03-2025, 07:47 AM
Last Post: Tazdevl
Tongue Yet another Pinebook Pro won't boot thread pinemouth 5 12,924 12-27-2024, 11:38 AM
Last Post: akash3995
  broken tow-boot hashkeeper 1 4,593 12-25-2024, 10:12 PM
Last Post: jessipinkman
  Unable to boot? YossiS 4 4,710 09-04-2024, 10:35 AM
  uboot wont boot to SD card after upgrade jbradley419 7 9,749 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 2,959 01-16-2024, 09:17 AM
Last Post: jbradley419
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 11,734 12-15-2023, 02:11 PM
