Unable to boot?
My brand new pine book pro has never worked! So far I have gotten the green power light to turn on and that's all.
I was told to flip the emmc switch to on, which made it so the green power light doesn't turn on anymore, and I wrote a Manjaro ARM gnome photo 23.02 img.xz file use etchDroid on a 32gb Sandisk SD card. I placed that in the Pinebook after turning the emmc switch off again but it hasn't made a difference .
Let me know, all I want is to be able to turn on the laptop and use the browser and libre office writer or whatever.
Why does it have to be so hard to turn on a computer?
Well, it does turn on and does boot, partially based on your report.
Try booting from micro SD with the eMMC switch turned off. If that doesn't work, your SD card isn't bootable.
I know it's not obvious but there are probably dozens of threads exactly like this here.
:wq
FWIW, on means disable on, I know, this is sort of backwards
I would suggest, try armbian (with emmc disabled),, if you get a boot, fsck the emmc partitions
(use lsblk to get device ids)
this may be, yet again, manjaros defective uboot
What are the steps to create a bootable micro SD card?
All images have idbloader and uboot in 1st 16M
Assume that it is a xz compressed image, if any compressed file is corrupt it will error out
xzcat image|dd of=/dev/sdcard bs=1M ; sync (replace sdcard with appropriate device)
But, BUT, if manjaro is on emmc, it may prevent uSD boot (since emmc has priority in search order for idbloader)
(and manjaro's uboot is defective)
test by disabling emmc (or removing) and see if it now boots
if so, do switch dance (so you have a dev for emmc, then change uboot there) or install tow-boot to SPI
Sad What to can't boot from TF card, EMMC system broken - any advice?do guys? qingss0 1 2,330 12-18-2025, 01:05 AM
Last Post: qingss0
  Bonk to boot biketool 2 2,953 10-21-2025, 09:08 AM
  3 days in, slow/stuck or no boot. lgmpbp2 34 33,418 06-11-2025, 08:53 AM
Last Post: lgmpbp2
  upgrading u-boot--what version? where to get it? bsammon 14 20,541 04-03-2025, 07:47 AM
Last Post: Tazdevl
Tongue Yet another Pinebook Pro won't boot thread pinemouth 5 12,916 12-27-2024, 11:38 AM
Last Post: akash3995
  broken tow-boot hashkeeper 1 4,588 12-25-2024, 10:12 PM
Last Post: jessipinkman
  Unable to use umlaut key combos ili 4 5,974 12-02-2024, 03:56 PM
  Cant boot into an OS trashtendenz 3 5,967 10-23-2024, 03:49 AM
Last Post: chaylengordon
  uboot wont boot to SD card after upgrade jbradley419 7 9,741 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 2,955 01-16-2024, 09:17 AM
Last Post: jbradley419
