Unable to use umlaut key combos
Hi guys,
the pinebook pro wiki says in the keyboard section it should be possible to type German umlauts by using key combos.
Ä, Ö, Ü, ä, ö, ü
[AltGr]+'[' followed by [A], [O], [U], [a], [o] or [u
I think i tried everything but i can't get it working.
I used Manjaro ARM Flasher and installed
pbpro kde-plasma 23.02
Is there anything else i need to do?
I left all settings unchanged
Hardware is set to Gerneric 104-key PC
Can anybody help me?
Thanks in advance.
What keyboard layout do you have selected in settings?
(10-01-2024, 12:49 PM)tophneal Wrote: What keyboard layout do you have selected in settings?
There was nothing selected.
I first tried English (US), which did not help.
Then tried English Western European AltGr dead key, better.
But I now get the big Ö when expecting the lower case ö.
Gone try some other layouts before editing one.
After reading the wiki i expected this to be a hardware function to work out of the box … silly me ;-)
Try if
AltGr + 2 + a gives you ä,
AltGr + 2 + o gives you ö,
and so on.
The only thing that I don't know is how to get a sharp s.
Should be on AltGr+s.
  Unable to boot? YossiS 4 4,323 09-04-2024, 10:35 AM
  Unable to Boot anything (emmc or SDcard) line72 5 6,905 01-17-2023, 12:07 PM
Last Post: nfms
  Unable to boot from emmc after flashing it rfm83 3 6,058 11-08-2022, 10:59 PM
Last Post: rfm83
  cannot boot SD card : "unable to select a mode" alchemist 0 4,499 06-18-2021, 02:03 AM
Last Post: alchemist
  I'm unable to open downloaded programs hayduke 9 15,753 06-09-2021, 02:34 PM
Last Post: jiyong
  Problem with Pinebook Pro unable to read mmc1 murda 2 6,522 11-22-2020, 03:08 PM
  Unable to connect to Wi-Fi with 802.11r enabled lrussell887 1 7,196 10-28-2020, 02:00 PM
Last Post: mammbo3
  Another Newb Unable to Boot From microSD JimmyJazz1971 3 6,962 10-26-2020, 03:48 AM
Last Post: JimmyJazz1971
  Unable to mount NVME (PineBook Pro) WallStreet 4 10,774 09-13-2020, 11:16 PM
Last Post: Phillip Bell
  Unable to boot: blinking red light houki 8 17,851 02-11-2020, 01:53 AM
Last Post: henryzhou
