Manjaro w/ Panfrost Drivers vs stock Debian Video Performance
I was just wondering how the video performance i.e. YouTube, Netflix, playing video files, games, etc. compares between Manjaro with Panfrost drivers and stock Debian. Also if anyone has played supertuxkart on the PBP, what graphics settings and FPS can I expect.
Thank you!
supertuxkart requires OpenGL ES 3.0, so I think you need a Kernel > 5.3 and mesa-git and also set the environment variable PAN_MESA_DEBUG=gles3
Netflix is also not a current possibility for any kind of benchmarking on Manjaro. There is no aarch64 Widevine available to be able to watch it.
you can run supertuxkart with gles2 in a low graphics mode. using gles3 it can support graphics quaility 2. I was getting 60fps in testing.
vaapi for wayland just landed in firefox nightly, and hantro/rkvdec are improving in kernel 5.7.
ask the question again in may Wink.
(03-02-2020, 08:10 AM)tophneal Wrote: Netflix is also not a current possibility for any kind of benchmarking on Manjaro. There is no aarch64 Widevine available to be able to watch it.
Will Netflix work via a Kodi?
As there is currently no Kodi which works on PBPro i guess Netflix will also not work.
Even if there were a Kodi available to use, likely not, since Netflix requires Widevine. Without an aarch64 Widevine, no Netflix at all.
I thought it was possible to extract widevine from chromium os builds
32bit aka armhf only at present
kodi works fine on pbp, including 18.6 just released.
(03-02-2020, 08:06 AM)maxjrh Wrote: supertuxkart requires OpenGL ES 3.0, so I think you need a Kernel > 5.3 and mesa-git and also set the environment variable PAN_MESA_DEBUG=gles3
Setting the environment variable breaks the game. The graphics don't render. I am running Manjaro with Panfrost drivers.
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 8 7,435 06-26-2025, 09:20 PM
Last Post: reukiodo
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 1,110 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 1,443 02-19-2025, 12:49 PM
Last Post: zkajdan
  Inexpected reboot during watching youtube video regivanx 1 736 10-19-2024, 06:02 AM
  Official Debian support moonwalkers 64 77,924 07-08-2024, 01:40 PM
Last Post: Humid Stylus
  (xorg) Video driver? falken 2 1,460 07-03-2024, 12:01 PM
Last Post: falken
  Debian on Pinebook Pro u974615 7 4,779 03-31-2024, 10:11 AM
Last Post: u974615
  Manjaro Sway Theme Broken Eighty8 1 1,457 03-08-2024, 08:41 AM
Exclamation 'failed to open panfrost' after system update using archarm Puckla 1 1,494 03-01-2024, 06:46 PM
Last Post: Puckla
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 3,213 02-02-2024, 02:45 AM
Last Post: frankkinney
