(xorg) Video driver?
I recently installed Manjaro (minimal) to the nvme on my Pinebook and it works great. I would like to setup xorg but I'm not sure which video driver the Pinebook needs? I read it uses Mali GPU, which means nothing to me.
Edi: Well the framebuffer one works apparently. I'm actually really surprised that I have to use the framebuffer driver.
You can install one of the GUI-based images to an SD card (so that you don't have to overwrite your NVMe Manjaro install), boot it up, and have a look at how it's configured. `lspci -vvv` is a good place to start; it'll tell you what kernel module it's using for the GPU.
(07-03-2024, 03:09 AM)Pavlos1 Wrote: You can install one of the GUI-based images to an SD card (so that you don't have to overwrite your NVMe Manjaro install), boot it up, and have a look at how it's configured.  `lspci -vvv` is a good place to start; it'll tell you what kernel module it's using for the GPU.
I booted up sway in Armbian and used lspci and apparently it was using the framebuffer, but might take another look because I didn't use the -vvv flags/switches
  Inexpected reboot during watching youtube video regivanx 1 3,557 10-19-2024, 06:02 AM
  Streaming video sites tessa 1 3,358 01-19-2024, 03:47 AM
Last Post: similarwham
  No Video Out on PBP on all major distros misha64 9 10,822 11-28-2023, 01:41 PM
Last Post: zaius
  Audio Driver on the pbp korreckj328 5 7,047 05-01-2023, 12:58 PM
Last Post: korreckj328
  Manjaro update broke hardware video acceleration with mpv myself600 2 5,030 01-25-2023, 09:12 AM
Last Post: myself600
  Testing a broken Vulkan driver LivingLinux 0 3,083 09-26-2022, 05:08 AM
Last Post: LivingLinux
Sad 1080p60 video on PBP Linux chewie 2 6,900 08-03-2021, 09:43 AM
Last Post: chewie
Bug 4K@30 video output does not work properly on Pinebook Pro jkm 0 4,189 06-29-2021, 08:43 AM
Last Post: jkm
Lightbulb Hardware video acceleration in Chromium on Manjaro siemsenit 3 9,562 06-01-2021, 09:51 AM
Last Post: siemsenit
  Very bad video playback ksinar 1 5,724 11-23-2020, 08:34 PM
Last Post: xyzzy
