Has your NVMe affected your battery at all?
#21
@tophneal I'm just curious - so asking. As far as I understand that Sabrent is working properly ?
#22
(01-17-2020, 02:02 PM)as400 Wrote: @tophneal I'm just curious - so asking. As far as I understand that Sabrent is working properly ?
"Yes" the PBP still booted, and I was able to use it as a shared drive. However, due to its only operational power states using so much power, I pulled it and am putting it in post to be returned tomorrow. A replacement KingSpec is on the way to replace it.
#23
(01-17-2020, 02:09 PM)tophneal Wrote: "Yes" the PBP still booted, and I was able to use it as a shared drive. However, due to its only operational power states using so much power, I pulled it and am putting it in post to be returned tomorrow. A replacement KingSpec is on the way to replace it.
Did you post these power states somewhere ?
They don't necesarily mean a lot. If nvme-cli doesn't have a plugin to communicate to nvme controller they can be very misleading.
Look at my case. My drive reports 7W at the lowest but I can see it's not using that much.
#24
I think I tried to, but work got in the way. Someone else with a PBP is using one, though. It was already on the wiki table when I went to add it. Maybe we can find them and have them post it. No way that's going back in my PBP after this headache, though.
I understand it may not have been entirely reflective/accurate, but it was seriously sucking power out of the battery. From that first boot, I had less than 5 hours use on the charge.
#25
I absolutely understand.
BTW - your wallpapers are the best Smile Do you have something in common with graphics ?
#26
(01-16-2020, 02:35 PM)tophneal Wrote: Earlier this week I got a Sabrent Rocket NANO 512 to try out in my PBP as a shared data drive.
Upon installation and first boot, everything seemed hunky-dory and normal. I took it to work, as usual, and noticed more battery drain than normal. After poking around with nvme-cli, I learned that drive doesn't have ideal power consumption or power savings settings for the PBP.
That might explain why their presales department still hasn't answered my question on the subject.  Too bad.  It looked so promising!
Just out of curiosity, did you save the text of the listing of power states from nvme-cli before you returned the drive?
Speaking of promising but untested 2242 drives, I just ordered a Lexar NM520 M.2 2242 256GB NVMe drive from Amazon for $50.  I'll post the nvme-cli results as soon as I get it into a machine.  I was hoping to get the 120 GB model for $30 but it went out of stock.
#27
(01-17-2020, 02:28 PM)as400 Wrote: I absolutely understand.
Thanks! It's actually my profession.
Unfortunately, no. I wish I did, but it's not worth putting it back in the PBP to get the table of states IMO.
Don't forget to update the wiki, too!
#28
(01-17-2020, 02:49 PM)tophneal Wrote: Thanks! It's actually my profession.
Heh - I knew it. It is very noticeable Smile
#29
Probably for the best. I've invested a lot of time and most of years in it lol
#30
(01-17-2020, 03:01 PM)tophneal Wrote: Probably for the best. I've invested a lot of time and most of years in it lol
Smile
  NVMe drives not detected mattpenn 18 21,145 12-24-2024, 08:54 PM
  NVMe reukiodo 0 1,613 11-18-2024, 09:00 AM
Last Post: reukiodo
  New Working nVME gilwood 1 2,666 11-17-2024, 04:24 AM
Last Post: reukiodo
  Bad replacement battery? chris88233 4 4,243 11-14-2024, 06:05 PM
Last Post: reukiodo
  Lithium Battery Connector Franestra 0 1,971 04-02-2024, 01:52 AM
Last Post: Franestra
  Bypassing the Battery gilwood 0 2,009 02-01-2024, 10:45 AM
Last Post: gilwood
  PBPro Battery specification Perl6_user 3 3,131 12-26-2023, 04:28 PM
Last Post: DrYak
  Replacement battery for PineBook Pro DrYak 3 4,867 11-07-2023, 10:09 AM
Last Post: DrYak
  Battery replacement mjc 2 5,118 09-26-2023, 01:08 AM
Last Post: david-lechner
  NVME problems 2022 / Intel 660p 1TB Starbug 1 3,765 04-04-2023, 12:16 PM
Last Post: globaltree
