NVMe
While I know about the NVMe compatibility matrix and TechPowerup's SSD database has much more info, I am still finding it difficult to find an optimal low-power large (2TB+) SSD.
From what I can determine so far from the SSD database, there are really 2 choices for low-power:
Only the Kingston is listed in the compatibility matrix, with comments are large battery drain. The compatibility matrix shows many other SSD options using less power, such as WD SN520 and Kioxia BG4.
Does the Power State X actually correlate to battery drain? And can it be forced to always disable all the high-powered states?
Something like SK Hynix Gold P31 2TB shows 6.3W (PS0) in the compatibility matrix, but only 3.3W max in the SSD database.
https://www.techpowerup.com/ssd-specs/sk...-2-tb.d443
Which one is accurate? Or are they both accurate and there are old versions which use more power?
  NVMe drives not detected mattpenn 18 31,104 12-24-2024, 08:54 PM
  New Working nVME gilwood 1 4,419 11-17-2024, 04:24 AM
Last Post: reukiodo
  NVME problems 2022 / Intel 660p 1TB Starbug 1 5,700 04-04-2023, 12:16 PM
Last Post: globaltree
Thumbs Up NVMe adapter, Great addition dachalife 2 5,386 11-28-2022, 12:56 PM
Last Post: dachalife
  NVme intall usage? tkudog 2 6,365 03-04-2022, 01:29 AM
Last Post: Tazdevl
  Anyone selling a spare NVMe adapter in Europe? tom.tomasz 1 4,518 01-03-2022, 07:57 AM
Last Post: tom.tomasz
  NVMe SSD testing methodology halogen 1 5,652 07-22-2021, 05:57 PM
Last Post: calinb
Question Battery stops charging and NVMe and other media disconnect randomly Eey0zu6O 4 10,563 07-09-2021, 08:45 PM
Last Post: moonwalkers
  nvme drive disappears after about an hour of uptime codebreaker 24 60,205 02-09-2021, 11:32 PM
Last Post: dsimic
  NVME SPI Update not booting SD Card WZ9V 5 11,823 10-18-2020, 08:36 PM
