Lithium Battery Connector
Greetings,
I need to know the 7-pin connector that is used to connect the battery pack to the mainboard on the Pinebook Pro... according to the schematic the boardside connector is JSQ1201WR-7P, however I could not find any more information to this on the internet. What I really am looking for is the cable side connector name, and if I could order it somewhere... I have seen a few posts on this forum asking something similar, but no answer this far...
There are also 2 types of connector, one from an older version and a newer one, as far as I can tell? Does anyone have any information?
Thanks!
  Replacement battery for PineBook Pro DrYak 5 9,587 02-28-2026, 09:17 PM
  Bad replacement battery? chris88233 4 7,211 11-14-2024, 06:05 PM
Last Post: reukiodo
  Bypassing the Battery gilwood 0 2,865 02-01-2024, 10:45 AM
Last Post: gilwood
  PBPro Battery specification Perl6_user 3 4,933 12-26-2023, 04:28 PM
Last Post: DrYak
  Battery replacement mjc 2 6,752 09-26-2023, 01:08 AM
Last Post: david-lechner
  Battery drain when off srs5694 1 3,515 03-24-2023, 06:05 PM
Question Battery stops charging and NVMe and other media disconnect randomly Eey0zu6O 4 10,611 07-09-2021, 08:45 PM
Last Post: moonwalkers
  Battery doesn't charge mspohr 5 10,505 06-11-2021, 08:42 AM
Last Post: mspohr
  Pinebook Pro broken eDP connector Ocawesome101 4 12,334 01-16-2021, 11:42 PM
Last Post: dsimic
Question Powering off & won't power back on w/o battery disconnect jimsurvak 5 10,433 11-10-2020, 08:42 PM
