Pine Phone won't boot into recovery mode
I have a pinephone pro explorer edition which just simply refuses to boot into recovery mode. I am trying to put arch-arm onto it, I've flashed the microSD, put it in the phone, but I cannot get the phone to boot from it or boot into recovery mode. I have tried every method I could find. Every time it either boots into the current os, or the led flashes red a bunch of times and the phone vibrates a lot before just turning off again. I have tried multiple SD cards and multiple flashes. No clue where to go from here it's been driving me nuts all week.
(02-17-2023, 06:50 PM)ninjapig26@gmail.com Wrote: I have a pinephone pro explorer edition which just simply refuses to boot into recovery mode. I am trying to put arch-arm onto it, I've flashed the microSD, put it in the phone, but I cannot get the phone to boot from it or boot into recovery mode. I have tried every method I could find. Every time it either boots into the current os, or the led flashes red a bunch of times and the phone vibrates a lot before just turning off again. I have tried multiple SD cards and multiple flashes. No clue where to go from here it's been driving me nuts all week.
technically speaking, there is no "recovery". you probably meant tow-boot's usb mass storage mode. if there is a screw up in tow-boot, you probably need to reinstall it, https://tow-boot.org/devices/pine64-pinephonePro.html .
you may have to use "re" button to boot sdcard, https://wiki.pine64.org/wiki/PinePhone_Pro#Boot_order .
Well I've certainly tried holding "re" to boot from sd to no avail, as well as every other possible button combination I could think of. I'm not familiar with what tow boot is or how to use it. I'll have a read and see what I can do, thanks for your time.
Please double-check, does the button label state "RESET" or "RE"? What is the exact filename of the image you were flashing on the microSD card and what is the exact tool or full command you used for flashing? Make also sure the microSD card is in the top slot.
  Pine Phone Pro audio on phone calls: discussion, support and tips apink 50 65,124 10-13-2025, 07:46 AM
Last Post: Habbytm
  July 1 upgrade of Mobian Bookworm boot loops. mburns 9 9,531 02-25-2025, 08:27 AM
  Installing r2kaw and Tow-Boot to the SPI ethical_haquer 10 10,030 12-19-2024, 05:22 PM
Last Post: dukla2000
  tow-boot installation problem techariah 4 8,049 12-04-2024, 10:32 AM
Last Post: zetabeta
  How can boot from MicroSD after replacement of the main board u-kidjp 6 6,453 11-08-2024, 09:14 PM
  tow-boot, just bought pinephone pro stratofall 4 5,175 07-30-2024, 03:43 PM
Last Post: stratofall
  Tow-Boot, a new U-Boot option for Pinephone Pro and other devices Ulfnic 60 103,925 02-13-2024, 02:54 PM
Last Post: fxc
Brick Recovery without Tow Boot b34ux 10 11,431 02-02-2024, 07:07 PM
Last Post: reky
  Guide to Suitable Phone State Borealid 19 27,517 09-18-2023, 07:00 AM
Last Post: robocone
  What to do if your PinePhone Pro does not boot fxc 19 46,701 09-10-2023, 03:19 AM
Last Post: fxc
