July 1 upgrade of Mobian Bookworm boot loops.
It must be the kernel update then. I can continue to boot from the Trixie installation on the main chip. And then use my rescuemobian script to continue trying the upgrades on the Bookworm installation. Edit this to your installation, and then continue to try upgrades from this temporary environment.
#! /bin/bash
cd /home/d1/root
mount /dev/mmcblk1p1 /home/d1/boot
mount --bind /proc /home/d1/proc
mount --bind /sys /home/d1/sys
mount --bind /dev /home/d1/dev
mount --bind /run /home/d1/run
chroot /home/d1
(07-02-2024, 10:41 AM)mburns Wrote: It must be the kernel update then. I can continue to boot from the Trixie installation on the main chip. And then use my rescuemobian script to continue trying the upgrades on the Bookworm installation. Edit this to your installation, and then continue to try upgrades from this temporary environment.
#! /bin/bash
cd /home/d1/root
chroot /home/d1
Never mind then. I will treat this as a failing microSD card, and just remove it. Updates are slow. This is the second chip to be removed for this.
So. Updating another installation of Mobian on another microSD card causes a failure to boot again, Bookworm or Trixie. Has support in Mobian for booting from the removable chip lapsed?
(08-13-2024, 06:26 AM)mburns Wrote: So. Updating another installation of Mobian on another microSD card causes a failure to boot again, Bookworm or Trixie. Has support in Mobian for booting from the removable chip lapsed?
I repaired the boot menu file on the second chip. This was needed to get a second boot on the PPP with recent Mobian. /boot/extlinux/extlinux.conf is the file that needs repair for the incomplete menu entry.
Today, October 19, 2024, I had to disable the GDM service after a Debian/Mobian update. I used ssh to fix the usability issue.
(10-19-2024, 01:54 PM)mburns Wrote: Today, October 19, 2024, I had to disable the GDM service after a Debian/Mobian update. I used ssh to fix the usability issue.
Today, October 26, 2024, an automatic update of Debian disabled Mobian Trixie. I had to copy in a spare copy of /etc/systemd/system to recover.
The 6.12 linux kernel updates on Mobian are simply not supporting the PinePhone Pro. The backlight control is failing and everything is laggy.
I go into the extlinux.conf and specify the 6.6 kernel as default - very zippy by comparison.
(01-08-2025, 12:14 PM)mburns Wrote: The 6.12 linux kernel updates on Mobian are simply not supporting the PinePhone Pro. The backlight control is failing and everything is laggy.
The 6.12 kernel might be OK now.
The Console app confused me. This is because the arrow keys are now superseded by gestures on the space key.
With the Mobian updates from the command line (Tues Feb 18 2025):
# apt update && apt upgrade
I periodically must enter the following command to restore fast processing and prevent hangs:
# systemctl disable gdm
If you are using another display manager, and you cannot uninstall gdm due to dependencies, then try:
sudo systemctl mask gdm
  Experimental Mobian kernel patch for extended battery life teekay 15 16,491 10-27-2025, 08:43 AM
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 21 21,226 10-20-2025, 07:01 AM
  Debian vs Mobian henrythemouse 3 3,593 04-06-2025, 02:15 AM
Last Post: henrythemouse
Rainbow Plasma-Mobile on Mobian Trixie, task switcher issue pineconeuser 0 2,096 01-02-2025, 09:21 AM
Last Post: pineconeuser
  Installing r2kaw and Tow-Boot to the SPI ethical_haquer 10 9,260 12-19-2024, 05:22 PM
Last Post: dukla2000
  tow-boot installation problem techariah 4 7,561 12-04-2024, 10:32 AM
Last Post: zetabeta
  How can boot from MicroSD after replacement of the main board u-kidjp 6 5,918 11-08-2024, 09:14 PM
  Megapixels on Mobian Bookworm on PinePhone Pro - Not Launching X0X0X0X0X0 3 5,065 10-28-2024, 10:46 AM
Last Post: Jite
  tow-boot, just bought pinephone pro stratofall 4 4,796 07-30-2024, 03:43 PM
Last Post: stratofall
  Tow-Boot, a new U-Boot option for Pinephone Pro and other devices Ulfnic 60 100,935 02-13-2024, 02:54 PM
Last Post: fxc
