How can boot from MicroSD after replacement of the main board
I just got a new main board of the PPP and replaced it from old broken one.
After replacement of the main board, my PPP only boots into AOSP android after displaying "Rockchip kernel" splash.
I tried with powering on with volume-down button, couldn't boot. With volume-up button, it goes into the android recovery mode,
I also tried with RE-button, but I got no response.
Is there any way to boot from MicroSD?  Huh
I would start with finding out what Bootloader is on your SPI.
https://pine64.org/documentation/PinePho...otloaders/
(11-04-2024, 09:32 AM)mikehenson Wrote: I would start with finding out what Bootloader is on your SPI.
How can I find my Bootloader?
From Android OS?. Huh
Are you sure you have a PinePhonePro?
I do not know everything, but the only android I know of is for the original PinePhone.
(11-05-2024, 08:15 AM)mikehenson Wrote: Are you sure you have a PinePhonePro?
if my memory serves correctly: pp pro first versions were installed by chinese version of basic android.
(11-03-2024, 08:12 PM)u-kidjp Wrote: I just got a new main board of the PPP and replaced it from old broken one.
rough plan:
prepare tow-boot installer into sdcard.
use RE-button to boot that sdcard.
optional, wipe spi mem.
install tow-boot into spi mem.
prepare distro to a sdcard, could be same sdcard.
boot using volume down button from sdcard.
alternate plan:
boot using volume up into mass mem mode.
optional, wipe internal mem.
option a, install distro into internal mem.
option b, install distro into sdcard mem, sdcard needs to be inserted.
if spi is empty or wiped, then phone boots from internal memory first.
Yes, PinePhonePro.
Android status says, Device Name rk-3399-mid, Device Storage Size = 128GB. These are compatible with PPP, no PP.
rough plan:
alternate plan:
Thanks, I tried tow-boot installer with RE button once again and it seems to be finished successfully.
(but, android don't boot any more)
I will try to install Manjaro or Mobian.
No surprise that Android (AOSP test image) does not boot anymore after installing Tow-Boot. Android boots only using its own fastboot bootloader, which in turn cannot boot anything else. So, as you wrote, the next step is to install a proper GNU/Linux operating system image.
  July 1 upgrade of Mobian Bookworm boot loops. mburns 9 9,145 02-25-2025, 08:27 AM
  Installing r2kaw and Tow-Boot to the SPI ethical_haquer 10 9,648 12-19-2024, 05:22 PM
Last Post: dukla2000
  tow-boot installation problem techariah 4 7,755 12-04-2024, 10:32 AM
Last Post: zetabeta
  tow-boot, just bought pinephone pro stratofall 4 4,977 07-30-2024, 03:43 PM
Last Post: stratofall
  Tow-Boot, a new U-Boot option for Pinephone Pro and other devices Ulfnic 60 102,552 02-13-2024, 02:54 PM
Last Post: fxc
Brick Recovery without Tow Boot b34ux 10 11,180 02-02-2024, 07:07 PM
Last Post: reky
  What to do if your PinePhone Pro does not boot fxc 19 45,961 09-10-2023, 03:19 AM
Last Post: fxc
  Pine Phone won't boot into recovery mode ninjapig26@gmail.com 3 6,360 02-18-2023, 06:14 PM
Last Post: fxc
  create tow boot .img fox95 6 9,894 10-21-2022, 11:40 AM
Last Post: fox95
  No display on early boot after Manjaro update robocone 0 2,335 07-07-2022, 05:47 AM
Last Post: robocone
