tow-boot, just bought pinephone pro
My pinephone pro came with sailfish and I believe U-boot ...
I've been trying to try different OS's from the wiki using sdcard.
Some work, some don't.
I assume a lot of the ones that don't work I need to install tow-boot.
My issue is...
I have the tow-boot spi on an sdcard.
I push in the re button and then the power button. (I have tried plugging in power via usb as well).
But, nothing happens. It never boots to the spi install screen.
Is there something I am doing wrong in this regard?
Also, if I ever do get tow-boot installed, how do I revert to a stock U-boot? I have not seen instructions for doing so with the reading I have done yet.
Any help is appreciated. I am just tired of iOS and android and tired of throwing away phones. I am hoping pine64 and its open nature can satiate my basic needs.
(07-29-2024, 05:30 AM)stratofall Wrote: My pinephone pro came with sailfish and I believe U-boot ...
My issue is...
When did you buy/get your PinePhonePro?
Tow-Boot needs to be flashed to the SPI. It will not work on the SD card.
My issue is...
https://wiki.pine64.org/wiki/PinePhone_P...ory_builds
I received my PinePhone Pro last week (week of July 22 2024) . I played around with Sailfish OS that came with it for a bit, just to see what it was like.
I have tried Arch with phosh. I then wanted to try Postmarket OS. But this one will not work at all. So I assumed it was a tow-boot. I also tried Kali, but it also would not work. So again tow-boot.
I download the latest tow-boot libreComputer-rocRk3399Pc-2023.07-007.tar.xz .. I write the spi.installer.img to the sdcard using dd if=spi.installer.img of=/dev/sda bs=1M oflag=direct,sync status=progress then put that sdcard into the phone, insert battery. Push the re button and then the power button and hold until something happens.
The phone seems to turn on and all I get is a blue LED light up. Nothing else....
Also, thanks tllim for the factory build link. I guess I meant/clarify if I am to install tow-boot at some point. How do I get the original u-boot back onto the phone?
So, I'm an idiot. Smile
I just realized the tow-boot list has a drop down to show more.
I found the pine phone pro version. And I was able to flash two-boot on the first try.
Welp, lesson learned. Thanks for taking the time.
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 21 22,226 10-20-2025, 07:01 AM
  Bare metal on Pinephone Pro alain 0 3,620 08-19-2025, 07:58 AM
Last Post: alain
  Seeking Contributors: Apache NuttX Real-Time Operating System for PinePhone Pro lupyuen 4 7,991 08-19-2025, 01:38 AM
Last Post: geometrylitegame12
Star FreeBSD developer build for PinePhone Pro teekay 1 2,846 05-03-2025, 11:02 AM
  freeBSD is booted on pinephone pro with console output zetabeta 5 5,869 04-18-2025, 12:56 AM
Last Post: teekay
  How to Clone Kali Linux to PinePhone Pro with Terabyte IFW TOF 2 5,987 02-26-2025, 02:15 AM
Last Post: TOF
  July 1 upgrade of Mobian Bookworm boot loops. mburns 9 9,314 02-25-2025, 08:27 AM
  Anyone gotten latest Ubuntu Touch to work on PinePhone Pro? dchang0 4 9,318 12-22-2024, 04:21 PM
Last Post: dchang0
  Installing r2kaw and Tow-Boot to the SPI ethical_haquer 10 9,771 12-19-2024, 05:22 PM
Last Post: dukla2000
  tow-boot installation problem techariah 4 7,871 12-04-2024, 10:32 AM
Last Post: zetabeta
