eMMC modules
Has anyone installed a Pine64-supplied eMMC module on a Rockpro64?
  SKU: 64G eMMC (SDINBDA4-64G) mmc 5.1
I bought one because my older eMMC modules are unreliable:
  SKU: "Sandisk: 64G mmc 4.5
I can't get the Pine64-supplied (mmc 5.1) module to work, so Pine64 support kindly send me a replacement part in case the one they first sent was faulty. However, neither of them work and it is very difficult to even detect them in uBoot unless I do a cold-start, but they stop working as soon as I try to write to them. Most recently, I tested them by booting the latest Manjaro for the Rockpro64 from SD, which has the latest uBoot for the Rockpro64. Unfortunately, this made no difference at all (previously, I was using Debian to run OMV from SD card, but I want to run it from eMMC.
If you've had success using any eMMC module on the Rockpro64, please let me know the SKU and where you got it from.
Thanks,
  Tony.
(09-07-2022, 12:42 PM)ajtravis Wrote: ...
I got a 16Gb eMMC from Pine together with my RockPro64 in June 2018. Around March this year I realised from errors it was on its way to meet its maker, so in June I ordered 1 from AliExpress (as Pine64 P&P broke the deal) which works fine. This one - not a particular recommendation of the vendor but was the one I used.
Are you booting the board while dressed correctly :-) - you obviously have to have the eMMC installed so it is recognised but you also have to prevent the 3399 trying to boot from it.
Thanks, that's a FORSEE eMMC, which I've seen advertised for the Rockpro64. However, I thought I would get a compatible eMMC ordering direct from Pine64. I got two older (mmc 4.5) modules from eBay and they work, but are not reliable: I suspect your's might be the same, not failing due to their age, but unreliable because they are not fully compatible with the Rockpro64. The modules sold by Pine64 are mmc 5.1, and should be a lot more reliable: The mmc 5.1 modules work well in my Pinebook Pro, running Arbian or Manjaro, but I have to boot them from uBoot in the SPI - Neither my Rockpro64 nor Pinebook Pro will boot directly from eMMC.
I am, of course, dressed casually :-)
Thanks,
  Tony.
I've now bought a 16GB FORSEE eMMC 5.1 module recommended by dukla2000 and my Rockpro64 is booting and running OMV from it without any problems. I've been waiting a MONTH for the Pine64 support team to reply to my suggestion that they test the eMMC module they are supplying in a Rockpro64 and THREE MONTHS since I opened my ticket. I'm an enthusiastic supporter of the Pine64 project, but such a poor level of customer support seriously detracts from an otherwise wonderful project. Asking questions on a forum like this is no substitute for good customer support.
Bye,
  Tony.
  Can i use this Emmc for Rockpro 64 Supratec 2 5,168 12-20-2023, 09:12 AM
  Installation Debian on emmc: which U-Boot and where? vongillus 3 8,049 07-02-2022, 09:24 AM
Last Post: dkebler
  Flash to eMMC? Barugon 4 7,051 04-27-2022, 03:10 PM
Last Post: Barugon
  rockpro64 emmc GreyLinux 8 14,697 11-08-2021, 01:56 PM
Last Post: GreyLinux
  eMMC 128gb flailingeffort 1 4,675 01-18-2021, 04:42 AM
Last Post: Wizzard
  RockPro64 eMMC boot euu 4 11,972 08-24-2020, 11:07 PM
Last Post: t4_4t
  sw4 jumper for disabling eMMC boot / multiboot ChriChri 0 3,927 03-09-2020, 08:54 AM
Last Post: ChriChri
  Availability of 128GB eMMC ? Arwen 1 5,065 07-22-2019, 11:28 AM
Last Post: Arwen
  board not working with EMMC RockPro64Newbie 1 4,792 05-10-2019, 02:22 AM
Last Post: Unkn0wn
  EMMC not booting while SD does. Apokalypz 29 53,682 03-10-2019, 04:12 AM
Last Post: graham-r
