Pro NVMe adapter Does not fit ! ?
#50
(11-12-2019, 08:39 PM)bcnaz Wrote: One person reported he simply taped his module to the adapter instead of using that post/nut to eliminate that conflict.
    I have considered a similar idea,  using a thin metal band to wrap around the adapter and NVMe module.
  I have also considered trimming the adapter board a bit for some extra clearance in the track pad area.
 It does appear to me that there could also be some space problems if the NVMe module is a thicker one, such as with heat sinks on it.
   ( or double sided compared to single sided)
Currently I am content to get familiar with my new PBP,  and wait for the modified parts kit,
   it does seem like the original cable was a bit short even if there had not been any clearance problems..?
I posted a tutorial on how I fitted a 2280 NVMe. AFAIK it doesn't introduce any new ideas but it is fairly comprehensive, includes some comments on cable routing and has a picture of the final installation.
See https://forum.pine64.org/showthread.php?tid=8322 .
Pro NVMe adapter Does not fit ! ? - by bcnaz - 10-04-2019, 03:03 PM
RE: Pro NVMe adapter Does not fit ! ? - by hdk - 10-05-2019, 01:00 AM
RE: Pro NVMe adapter Does not fit ! ? - by bcnaz - 10-21-2019, 09:38 AM
RE: Pro NVMe adapter Does not fit ! ? - by bcnaz - 10-05-2019, 04:02 AM
RE: Pro NVMe adapter Does not fit ! ? - by hdk - 10-05-2019, 04:47 AM
RE: Pro NVMe adapter Does not fit ! ? - by hdk - 10-05-2019, 07:25 AM
RE: Pro NVMe adapter Does not fit ! ? - by bcnaz - 10-05-2019, 05:25 AM
RE: Pro NVMe adapter Does not fit ! ? - by hdk - 10-05-2019, 06:03 AM
RE: Pro NVMe adapter Does not fit ! ? - by hdk - 10-05-2019, 08:49 AM
RE: Pro NVMe adapter Does not fit ! ? - by ndp - 10-21-2019, 04:16 AM
RE: Pro NVMe adapter Does not fit ! ? - by bcnaz - 10-21-2019, 06:37 AM
RE: Pro NVMe adapter Does not fit ! ? - by Luke - 10-23-2019, 05:59 PM
RE: Pro NVMe adapter Does not fit ! ? - by bcnaz - 10-26-2019, 08:06 PM
RE: Pro NVMe adapter Does not fit ! ? - by bcnaz - 10-27-2019, 05:35 AM
RE: Pro NVMe adapter Does not fit ! ? - by bcnaz - 10-27-2019, 07:05 AM
RE: Pro NVMe adapter Does not fit ! ? - by bcnaz - 10-28-2019, 11:37 AM
RE: Pro NVMe adapter Does not fit ! ? - by bcnaz - 10-27-2019, 07:25 AM
RE: Pro NVMe adapter Does not fit ! ? - by bcnaz - 10-28-2019, 11:10 PM
RE: Pro NVMe adapter Does not fit ! ? - by bcnaz - 11-01-2019, 09:07 AM
RE: Pro NVMe adapter Does not fit ! ? - by bcnaz - 11-01-2019, 09:41 AM
RE: Pro NVMe adapter Does not fit ! ? - by Luke - 11-01-2019, 09:45 AM
RE: Pro NVMe adapter Does not fit ! ? - by nakato - 11-01-2019, 08:22 PM
RE: Pro NVMe adapter Does not fit ! ? - by sundog - 11-02-2019, 10:57 AM
RE: Pro NVMe adapter Does not fit ! ? - by Luke - 11-02-2019, 11:06 AM
RE: Pro NVMe adapter Does not fit ! ? - by sundog - 11-02-2019, 11:13 AM
RE: Pro NVMe adapter Does not fit ! ? - by Arwen - 11-02-2019, 11:23 AM
RE: Pro NVMe adapter Does not fit ! ? - by mdmbc - 11-03-2019, 06:55 PM
RE: Pro NVMe adapter Does not fit ! ? - by hdk - 11-11-2019, 05:49 AM
RE: Pro NVMe adapter Does not fit ! ? - by bcnaz - 11-12-2019, 08:39 PM
RE: Pro NVMe adapter Does not fit ! ? - by danielt - 11-14-2019, 07:23 AM
RE: Pro NVMe adapter Does not fit ! ? - by bcnaz - 11-22-2019, 12:45 PM
RE: Pro NVMe adapter Does not fit ! ? - by tllim - 11-25-2019, 01:04 AM
RE: Pro NVMe adapter Does not fit ! ? - by Thra11 - 11-25-2019, 10:19 AM
RE: Pro NVMe adapter Does not fit ! ? - by bcnaz - 12-03-2019, 02:47 PM
RE: Pro NVMe adapter Does not fit ! ? - by c6Q$! - 12-14-2019, 05:35 AM
RE: Pro NVMe adapter Does not fit ! ? - by zaius - 12-16-2019, 12:23 PM
RE: Pro NVMe adapter Does not fit ! ? - by bcnaz - 04-07-2020, 05:15 PM
RE: Pro NVMe adapter Does not fit ! ? - by Arwen - 12-16-2019, 05:51 PM
RE: Pro NVMe adapter Does not fit ! ? - by zaius - 12-16-2019, 06:54 PM
RE: Pro NVMe adapter Does not fit ! ? - by Arwen - 12-17-2019, 05:31 AM
RE: Pro NVMe adapter Does not fit ! ? - by zaius - 12-17-2019, 02:42 PM
RE: Pro NVMe adapter Does not fit ! ? - by bcnaz - 01-26-2020, 06:55 PM
RE: Pro NVMe adapter Does not fit ! ? - by zaius - 02-13-2020, 12:32 PM
RE: Pro NVMe adapter Does not fit ! ? - by zaius - 03-11-2020, 12:31 PM
RE: Pro NVMe adapter Does not fit ! ? - by tllim - 03-21-2020, 01:07 PM
RE: Pro NVMe adapter Does not fit ! ? - by bcnaz - 03-21-2020, 06:52 PM
RE: Pro NVMe adapter Does not fit ! ? - by tllim - 03-21-2020, 08:36 PM
RE: Pro NVMe adapter Does not fit ! ? - by bcnaz - 03-21-2020, 10:10 PM
RE: Pro NVMe adapter Does not fit ! ? - by bcnaz - 03-29-2020, 10:42 PM
RE: Pro NVMe adapter Does not fit ! ? - by Kaythe - 03-30-2020, 01:02 AM
RE: Pro NVMe adapter Does not fit ! ? - by bcnaz - 04-01-2020, 01:28 PM
RE: Pro NVMe adapter Does not fit ! ? - by bcnaz - 04-04-2020, 08:29 PM
RE: Pro NVMe adapter Does not fit ! ? - by bcnaz - 04-07-2020, 04:02 PM
RE: Pro NVMe adapter Does not fit ! ? - by josmo - 04-11-2020, 12:10 AM
RE: Pro NVMe adapter Does not fit ! ? - by Arwen - 04-14-2020, 10:41 AM
RE: Pro NVMe adapter Does not fit ! ? - by Arwen - 04-15-2020, 01:59 PM
  New Working nVME gilwood 0 230 02-12-2024, 08:46 AM
Last Post: gilwood
  NVME problems 2022 / Intel 660p 1TB Starbug 1 1,561 04-04-2023, 12:16 PM
Last Post: globaltree
Thumbs Up NVMe adapter, Great addition dachalife 2 1,826 11-28-2022, 12:56 PM
Last Post: dachalife
  NVMe drives not detected mattpenn 12 10,473 03-05-2022, 04:53 AM
Last Post: mattpenn
  NVme intall usage? tkudog 2 2,926 03-04-2022, 01:29 AM
Last Post: Tazdevl
  Anyone selling a spare NVMe adapter in Europe? tom.tomasz 1 1,874 01-03-2022, 07:57 AM
Last Post: tom.tomasz
  NVMe-related crashes and instability, plus a solution simonsouth 13 14,781 12-10-2021, 07:47 PM
Last Post: josmo
  Mini-Howto: ROCK64 USB 3.0 WIFI Adapter (Rabbit-ear) on Manjaro Dendrocalamus64 1 2,413 11-14-2021, 03:41 PM
Last Post: Dendrocalamus64
  NVMe SSD testing methodology halogen 1 2,647 07-22-2021, 05:57 PM
Last Post: calinb
Question Battery stops charging and NVMe and other media disconnect randomly Eey0zu6O 4 4,815 07-09-2021, 08:45 PM
Last Post: moonwalkers
