Manjaro Issues: Dark Screen & Font size
I download Manjaro KDE Plasma 20.10 last week.   I have two issues I don't have a clue to solve.
!. Pinebook Pro, screen is dark
2. Font size is to small to read or see... increased the font sizes but website size don't change.
Thank you for any assistance you can give me.
My regards,
Let me clarify what I mean by a dark screen.
My computer came with Ubuntu, lighting was not an issue. I download Manjaro KDE Plasma on an extra 64gb eMMC card. The set up of Manjaro went fine. The screen was dark after it booted up and I attempt to use the keys F1 and F2 to brighten up the screen, no luck.
(12-14-2020, 09:51 PM)Sally2 Wrote: Hi,
My regards,
My vision is not very good, and Linux distros overall are still very poor with accessibility issues. Manjaro is very dark and I faced the same problems. In the KDE Plasma Menu (It opens with the Pine Logo key) you need to select System settings. Once the System Settings window has opened, you can select "Global Theme" and with that open you can select the Breeze theme, once applied that will open all windows with a light background.
With that done you can select the "Display settings" which will allow you to change the screen scaling to something easier to read. Personally I pick 1.5. After that is selected you need to restart the computer for the scaling to take effect. It should then restart to an interface that is much lighter and easier to read.
Personally I took my Pinebook Pro up to the local library, where I found a friendly helpful person who was able to work with the default settings.
bill
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,732 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 6,450 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,577 02-19-2025, 12:49 PM
Last Post: zkajdan
  Attempting to install Void Linux, boots into a black screen 9a3eedi 1 7,080 09-28-2024, 09:23 AM
Last Post: throwawayforvoid
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 4,827 05-31-2024, 09:42 AM
Last Post: SynthGal
  Manjaro Sway Theme Broken Eighty8 1 4,231 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 6,768 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 4,109 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,448 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 11,719 12-11-2023, 03:47 AM
Last Post: calinb
