[Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both
Greetings everyone, just got a used Pinephone Pro (and a pinephone but haven't used that yet) and am trying to dredge up years-old pre-brain surgery Linux knowledge to make this thing work as a palmtop full time. Currently I am running Mobian with XFCE and I am working on getting the keyboard and the screen rotation working correctly. With regards to the screen, I have two lines in /etc/lightdm/lightdm.conf (which may be the wrong place but one tutorial mentioned it so I'm using it for now)
[Seat Defaults]
display-setup-script = xinput set-prop "pointer:Goodix Capacitive TouchScreen" --type=float "Coordinate Transformation Matrix" 0 1 0 -1 0 1 0 0 1
display-setup-script = xrandr --output DP-1 --off --output DSI-1 --primary --mode 720x1440 --pos 0x0 --rotate right
The first line fixes the touchscreen so I can use it in landscape mode from within the OS. The second makes the greeter landscape, but now the touchscreen is equally broken (swipe to the right, cursor going up) in both the greeter and the OS itself because the first line is "cancelled out." If I comment out the second line, the first works.
I've barely managed to scrape these solutions together from tutorials and I have no idea why one would mess with the other and I'm completely lost. Any ideas? Ask me anything and I'll answer what I can.
(Also I'm doing my best to follow the rules but my reading comprehension is not the best so please if I am breaking any I swear it's an accident and will correct it asap)
  Boot Order in Pinebook Pro food 12 19,283 05-25-2026, 08:28 AM
Last Post: finmark
  Window Maker Live for Pinebook Pro vajak 9 6,578 05-20-2026, 06:55 AM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 14,272 08-09-2025, 06:53 AM
Last Post: Sb2024
  Attempting to install Void Linux, boots into a black screen 9a3eedi 1 7,043 09-28-2024, 09:23 AM
Last Post: throwawayforvoid
  Pinebook pro won't boot after bootloader installation jwensouls 4 8,698 08-21-2024, 04:17 AM
  Debian on Pinebook Pro u974615 7 12,519 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 17,824 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,404 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 11,635 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 164,858 12-08-2023, 11:25 PM
