Working terminal emulator
Is there any terminal emulator that I can use with GLES 3.0 in PBP currently?
I tried to use Alacritty and the error log was saying that I need 3.3 or higher support.
for alacritty you need to use cyclopsian's gles3 (or gles2) port patch. i've been playing with the gles3 port with mesa-git and will add to pbp-tools. thanks for the reminder.
(06-19-2020, 02:51 PM)xmixahlx Wrote: for alacritty you need to use cyclopsian's gles3 (or gles2) port patch. i've been playing with the gles3 port with mesa-git and will add to pbp-tools. thanks for the reminder.
Could you let me know where can I find the patch?
Here you go: https://github.com/cyclopsian/alacritty/tree/gles3
Thank you, I really appreciate it.
However, I am new to Manjaro and even Linux so, not sure how to the port patch from there.
Should I build Alacritty from the cyclopsian source or need only a part of it?
the pbp-tools script grabs the commit and patches 0.4.2, but you can do that a bunch of different ways.
https://github.com/xmixahlx/pbp-tools/bl...-alacritty
fwiw this is working for me on pinebook pro, manjaro arm, with no patches. I had to install the latest mesa driver, and run it with an extra environment variable but it works:
relevant commands:
pamac install alacritty mesa-git
PAN_MESA_DEBUG=gl3 alacritty
same thing worked for kitty terminal emulator too https://sw.kovidgoyal.net/kitty/
Thumbs Up Finally got Kali working on my Pinebook Pro! qingss0 0 1,975 04-04-2026, 08:00 AM
Last Post: qingss0
  bliuetooth not working in Armbian 22.11.1 Pinebook Pro River 0 2,419 12-09-2022, 04:48 PM
Last Post: River
  Mid 2022: what is in your humble opinion the best working OS for the PinePro? walterbe 3 6,727 06-29-2022, 02:00 PM
Last Post: Chief
Sad Webcam not working in pinebook pro with Manjaro jcarball 2 7,513 04-28-2021, 03:23 PM
Last Post: jcarball
  Built-in Webcam Not Working fozzedout 36 69,224 02-01-2021, 08:59 AM
Last Post: lemaurien19
  [split] U-Boot with NVMe support, keyboard & display working as400 78 142,206 01-27-2021, 12:48 AM
Last Post: as400
  Booting to sdcard stopped working after emmc flash techiedog 3 7,425 12-31-2020, 06:30 PM
Last Post: Anarethos
  Wifi stopped working after updates pineitup 10 19,381 11-07-2020, 02:59 AM
  Suspend with NVME not working - Default Debian appdev46 5 15,612 07-14-2020, 01:53 PM
Last Post: Jeremiah Cornelius
  USB-C to 4k monitor: right 1/3 not working robt 4 9,416 07-12-2020, 02:46 PM
Last Post: robt
