gcc v7.1 or higher distro? Manjaro have it?
Do we have a Distro to gcc versions somewhere? Smile
Need gcc 7.1 or higher and other build tools of course. What is the Distro I can use?
Manjaro 19.x have gcc 7.1 or higher ?
Thanks,
Mike
Debian Stable (Buster): 8.3.0-1
Manjaro current: 9.2.1+20200130-2
Daniel's Debian installer supports installing Buster.
https://forum.pine64.org/showthread.php?tid=8487
Manjaro Arm 20.04 has an image for PBP.
https://forum.pine64.org/showthread.php?tid=9918
20.0 is the latest release, so I guess that's the 9.2.1 above.
Manjaro has gcc 9.3.0 installed
debian has all of these, including gcc 10 in experimental
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,321 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 5,874 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 6,994 02-19-2025, 12:49 PM
Last Post: zkajdan
  Manjaro Sway Theme Broken Eighty8 1 3,946 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 6,458 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 3,823 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 9,992 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 11,156 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 3,335 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 5,156 11-14-2023, 10:57 AM
Last Post: trifleneurotic
