How to DD to emmc?
I'm trying to install Manjaro to my PBP's emmc.  I now have a blank screen as I believe I wrote the .img to the wrong drive. I do have it in SD card so I'm able to boot from SD but can someone tell me how to get out of this mess and install Manjaro to my emmc from sd?
Thanks!
(01-26-2020, 02:02 PM)Sats Wrote: Hi,
Thanks!
When you flashed your SD Card, did you use the eMMC installer image? If you did, the setup script should have guided you though the process of putting Manjaro on your eMMC. See if you can flash the eMMC installer image to your SD card. Click here and choose the emmc-installer from the list, if you have not done so all ready.
[url=https://osdn.net/projects/manjaro-arm/storage/pbpro/kde-plasma/19.12/][/url]
Thanks!
[url=https://osdn.net/projects/manjaro-arm/storage/pbpro/kde-plasma/19.12/][/url]I
I didn't see the emmc installer image.  I'll grab the installer from your link and follow from there.  Thanks!
I didn't see the emmc installer so I'm downloading it now And following your lead. Thanks!
I DD to SD card and restarted to a black screen. Any thoughts how I can fix this? thanks
Balena Etcher....
My opinion for transferring to the SD card, or if you have the USB to eMMC adapter (Pine store sells it, but others have found them on Amazon and Ebay)
Then you can install direct to the eMMC drive.
Also Great if you upgrade from the 64gb to the 128gb eMMC...
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
Thanks!
if the mrfixit kernel can be debianized (config anywhere?) you could make an "official" installer with debootstrap, similar to danielt.
as this is the "debian way" that would also be my preference.
+1 for Etcher
Do you get a black screen on boot?
(01-27-2020, 04:07 PM)LANStrider Wrote: +1 for Etcher
Yes black screen
  Need new eMMC Karsten1 1 1,726 07-22-2025, 03:10 PM
  Happy eMMC and SDcard OS usage for Pinebook Pro Newbies... Paulie420 42 85,055 11-20-2023, 06:22 PM
  I'm booting from NVME but I want to switch back to eMMC acruhl 4 4,043 04-23-2023, 06:58 AM
Last Post: acruhl
  Doesn’t power on after flashing emmc badguru 3 3,324 02-25-2023, 09:00 PM
Last Post: badguru
  eMMC problem with Tow-Boot/u-boot on SPI repa 3 3,632 02-21-2023, 01:49 AM
Last Post: repa
  Partial boot after installing Manjaro on emmc regivanx 11 7,704 02-06-2023, 09:11 AM
  Unable to Boot anything (emmc or SDcard) line72 5 4,716 01-17-2023, 12:07 PM
Last Post: nfms
  What OS have you recently flashed onto PBP eMMC? jcun4128 6 5,025 11-26-2022, 09:39 AM
  Unable to boot from emmc after flashing it rfm83 3 3,864 11-08-2022, 10:59 PM
Last Post: rfm83
  Pinebook picky about which EMMC will boot flatulent_piney 8 6,698 11-05-2022, 06:03 PM
Last Post: ajtravis
