setting up fedora from minimal install
Hi there,
I am interested in using Fedora on my Pinebook pro. However, I suspect Fedora Workstation would be a bit heavy for the specs. So, I am hoping to setup a lightweight Fedora from the minimal image. I came across a few problems with this:
1. What is the default username and the password for the login to the Fedora minimal?
2. How to connect to a wireless network from the Fedora minimal?
I want to setup Fedora with either LxQT or xfce. If there is good documentation, I would consider i3 or sway too.
Any help would be appreciated.
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 8 16,511 06-26-2025, 09:20 PM
Last Post: reukiodo
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 5,890 02-19-2025, 12:49 PM
Last Post: zkajdan
  Doing a fresh install docFarto 5 5,795 02-09-2025, 02:58 PM
Last Post: mikehenson
  Attempting to install Void Linux, boots into a black screen 9a3eedi 1 5,897 09-28-2024, 09:23 AM
Last Post: throwawayforvoid
  Fedora 37 installation gswatkins 16 18,454 03-16-2024, 03:09 PM
Last Post: michel_luc
  install debian on pbp jsch 7 10,941 11-22-2023, 04:22 PM
Last Post: TRS-80
  Fedora 36 -> 37 upgrade kills system tydeman 0 2,168 10-28-2023, 09:53 AM
Last Post: tydeman
  Install deepin OS on pinebook pro wangyukunshan 4 6,111 08-07-2023, 01:12 PM
Last Post: myself600
  Upgrade Fedora from 37 to 38? acruhl 2 3,545 07-12-2023, 09:31 PM
Last Post: acruhl
  Blank screen after Armbian 20.04 install to emmc? psychoacoustic 3 8,958 04-01-2023, 03:22 PM
Last Post: TRS-80
