Fedora 36 -> 37 upgrade kills system
Years ago, I found instructions on installing Fedora 32 to a SD card.  I can no longer find those instructions.
Since then I have been doing upgrades in place: 32 -> 33 -> 34 -> 35 -> 37 via:
  dnf --refresh upgrade
  dnf system-upgrade download --refresh --releasever=37
  dnf system-upgrade reboot
However, doing the 36 -> 37 upgrade appeared to work, but when I boot 37,
I get a Kernel panic (Attempted to kill init!) soon after Switch Root.
I am looking for either of two things:
1)  Fix the existing Fedora 37 system
2)  Start over with a clean install (need instructions)
Manjaro on the internal "disk" still works (if I remove the SD card).
So, I should have the ability to edit things on the SD card once Manjaro has booted.
  Fedora 37 installation gswatkins 16 6,026 03-16-2024, 03:09 PM
Last Post: michel_luc
Exclamation 'failed to open panfrost' after system update using archarm Puckla 1 331 03-01-2024, 06:46 PM
Last Post: Puckla
  Upgrade Fedora from 37 to 38? acruhl 2 913 07-12-2023, 09:31 PM
Last Post: acruhl
  upgrade problem trying4firstbass 1 794 11-28-2022, 01:44 AM
  Fedora Workstation (36) on Pinebook Pro u974615 13 7,308 09-02-2022, 11:24 AM
Last Post: u974615
  Is anyone successfully running guix system on PBP bluekeys 8 7,992 08-29-2022, 01:19 PM
Last Post: bluekeys
  No audio on Pinebook Pro with Fedora? foobar 1 1,411 08-22-2022, 12:12 PM
Last Post: snorwood
  what is the magic dd incantation to copy the system from the sd card to the emmc? geokon 18 9,276 08-18-2022, 11:26 PM
Last Post: calinb
  Fedora 33 to 34 upgrade issues tydeman 2 2,487 12-02-2021, 02:43 AM
Last Post: linuxfreund
  setting up fedora from minimal install pine76 0 1,330 11-30-2021, 10:47 AM
Last Post: pine76
