No audio on Pinebook Pro with Fedora?
I'm currently running Fedora with tow-boot on my Pinebook Pro, and mostly it's working great. One issue I haven't resolved yet that is specific to this distro, is lack of sound. I get the following errors on boot:
Aug 21 18:11:28 fedora alsactl[1161]: alsa-lib main.c:1541:(snd_use_case_mgr_open) error: failed to import hw:0 use case configuration -2
Aug 21 18:11:28 fedora alsactl[1161]: /usr/sbin/alsactl: set_control:1475: Cannot write control '2:0:0:ALC Capture Target Volume:0' : Invalid argument
I tried installing a kernel with patches from Manjaro via `kernel-pbp` from this Copr repo, but it requires a change to the boot procedure, possibly by uninstalling efi, grub and other packages, then installing the u-boot pacakge from that same repo. I'm tempted to try this, but would prefer not to make such radical changes to the boot process at this time. I did try installing their `pinebookpro-audio` package, but that wasn't enough to solve the issue.
Has anyone had any success with audio on Fedora?
I have the same issue. Don't quote me on this, but I believe that it worked with the default Fedora 36 installation and broke when I yum updated it. I haven't spent any mount of time trying to troubleshoot this, but figured that I'd post to indicate that you are not the only one with this issue.
  Debian on Pinebook Pro u974615 7 992 03-31-2024, 10:11 AM
Last Post: u974615
  Fedora 37 installation gswatkins 16 5,954 03-16-2024, 03:09 PM
Last Post: michel_luc
  Pinebook Pro upgrading from the factory image yamsoup 12 1,552 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,131 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,201 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 88,531 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 1,223 11-23-2023, 07:37 AM
  Fedora 36 -> 37 upgrade kills system tydeman 0 448 10-28-2023, 09:53 AM
Last Post: tydeman
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,246 08-31-2023, 04:20 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,471 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
