Fedora 33 to 34 upgrade issues
PineBook Pro still has Manjaro on its internal "disk".
I have Fedora 33 installed on a 64GB uSD card
(that mostly runs OK -- Shutdown does not turn machine off)
Today, I followed these instructions to upgrade from Fedora 33 to 34.
It appeared to work OK.
https://www.if-not-true-then-false.com/2...using-dnf/
How to upgrade from 33 to 34 (in place):
  NOTE:  Some of these steps take many minutes (appears system is hung)
su -
dnf --refresh upgrade
reboot
dnf install dnf-plugin-system-upgrade --best
dnf system-upgrade download --refresh --releasever=34
    ... takes a long time to download 3399 packages
dnf system-upgrade reboot
    ... takes a long time to install 3399 packages
su -
rpm --rebuilddb
dnf distro-sync --setopt=deltarpm=0
dnf install rpmconf
rpmconf -a
https://docs.fedoraproject.org/en-US/qui...m-upgrade/
    ... above plus these:
su -
dnf update
dnf repoquery --unsatisfied
dnf repoquery --duplicates
dnf list extras
That last command lists several packages, but the one I am worried about is:
  pinebook-pro-fixes.aarch64
and perhaps:
  ap6256-firmware.aarch64
The Dolphin file manager works OK.
System settings works OK.
But, firefox has issues.
  It starts and has a window with a title, but the main window is transparent;
  in that I see the desktop
Also, emacs has issues.
  Starting it from the desktop icon acts the same as firefox -- transparent window.
From a Konsole, starting either "emacs &" or "firefox &", I see warning from Gtk
that "window_decorations.css" is missing.
On the login screen, on the bottom left is as option to pick the Desktop Session. My system was in Plasma(Wayland). I switched to Plasma(X11) and that fixed my problems. So, I still do not know what the real problem is, but I have a workaround.
(11-20-2021, 09:00 AM)tydeman Wrote: On the login screen, on the bottom left is as option to pick the Desktop Session.  My system was in Plasma(Wayland).  I switched to Plasma(X11) and that fixed my problems.  So, I still do not know what the real problem is, but I have a workaround.
Hello, I can confirm the problem with Wayland since Fedora35.
Andreas
  Fedora 37 installation gswatkins 16 20,508 03-16-2024, 03:09 PM
Last Post: michel_luc
  Fedora 36 -> 37 upgrade kills system tydeman 0 2,442 10-28-2023, 09:53 AM
Last Post: tydeman
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 4,944 08-21-2023, 09:10 PM
Last Post: vanessadonald
  Upgrade Fedora from 37 to 38? acruhl 2 3,944 07-12-2023, 09:31 PM
Last Post: acruhl
  upgrade problem trying4firstbass 1 2,844 11-28-2022, 01:44 AM
  Hibernation and Speaker Sound Issues, First Month of PBP kebab 7 9,115 11-02-2022, 02:33 PM
Last Post: kebab
  Any chance of fixing the audio issues on the new batch PBP(it can't be just me...) crazyquark 0 2,420 09-30-2022, 10:15 AM
Last Post: crazyquark
  Fedora Workstation (36) on Pinebook Pro u974615 13 20,468 09-02-2022, 11:24 AM
Last Post: u974615
  No audio on Pinebook Pro with Fedora? foobar 1 4,575 08-22-2022, 12:12 PM
Last Post: snorwood
  setting up fedora from minimal install pine76 0 4,308 11-30-2021, 10:47 AM
Last Post: pine76
