Any chance of fixing the audio issues on the new batch PBP(it can't be just me...)
Hello all,
Two issues with audio on PBP that I see no way out of:
- the audio jack: when plugging in headphones with a TRRS plug - the mic is not detected, only the speaker function(someone on discord told me it might be related to alsa ucm2 - maybe because there is only a "High fidelity audio" profile available or something like that?)
- The internal mic picks up a TON of noise, messing around with the controls in alsa can reduce the noise, make it almost functional. If the audio jack mic would work then this is almost a non-issue, I do not want to use the integrated mic anyway.
I tried a bunch of distros - armbian, manjaro, arch(still working on it), kali - none of them have a properly working audio system.
Am I missing something obvious? Could my audio jack just be poorly wired or something?
P.S.
Also the popping and the hissing of the audio.... that has been reported by other users as well. I dealt with it by disabling suspend and switching to headphones(even if disconnected).
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 893 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,020 08-21-2023, 09:10 PM
Last Post: vanessadonald
  Audio on Armbian Hobbes42 1 843 08-04-2023, 01:18 AM
Last Post: Humid Stylus
  Audio Driver on the pbp korreckj328 5 1,680 05-01-2023, 12:58 PM
Last Post: korreckj328
  Hibernation and Speaker Sound Issues, First Month of PBP kebab 7 2,984 11-02-2022, 02:33 PM
Last Post: kebab
  manjaro on pinebook pro low audio quality over jack alcck 1 1,072 09-22-2022, 11:31 AM
Last Post: petersen77
  Install of ArchARM on latest pbp batch tallfrye 0 689 08-22-2022, 02:36 PM
Last Post: tallfrye
  No audio on Pinebook Pro with Fedora? foobar 1 1,409 08-22-2022, 12:12 PM
Last Post: snorwood
  Fedora 33 to 34 upgrade issues tydeman 2 2,485 12-02-2021, 02:43 AM
Last Post: linuxfreund
  Headphone jack & audio switching ThatGeoGuy 8 8,750 03-23-2021, 07:57 PM
Last Post: ab1jx
