Install of ArchARM on latest pbp batch
I am switching over my new pbp from Manjaro to ArchARM. I forgot what I put in for my user pw and couldn't find anything on a default pw for root, so failed to make a boot SD on the pbp, used a laptop with Slackware instead. I followed the instructions at github (Installation on microSD card or eMMC module) for making the SD card and installing it.
The first reboot put me at the Arch prompt, but 'wifi-menu' didn't work. I looked at PCI devices and nothing was showing up for wireless devices. Wifi was working under the default Manjaro. I went ahead with the rest of the install without a network connection. It didn't give any complaints while initializing and populating the keys.
I then went ahead and with the install for the eMMC (Installation on eMMC module without a USB adapter). I'm not sure what USB adapter is being referred to or how the install would go if I had one, figured this would work regardless. After a reboot, it goes through the Tow-Boot sequence, but then fails to mount /boot.
I repeated the process with rewriting the SD card but it gives me the same error. I looked through the journalctl logs and don't see anything more than generic error info, not sure what to report here. I can't exactly cut and paste with the state the pbp is in. There were some warnings and extra steps (keeping or removing a file system for the second partition) while preparing the SD that I made guesses on since they weren't mentioned in the install guide.
Not sure at this point if I should check this SD card for problems, try a different card, or a different install method...?
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 8 18,810 06-26-2025, 09:20 PM
Last Post: reukiodo
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,400 02-19-2025, 12:49 PM
Last Post: zkajdan
  Doing a fresh install docFarto 5 7,107 02-09-2025, 02:58 PM
Last Post: mikehenson
  Attempting to install Void Linux, boots into a black screen 9a3eedi 1 6,935 09-28-2024, 09:23 AM
Last Post: throwawayforvoid
Exclamation 'failed to open panfrost' after system update using archarm Puckla 1 4,146 03-01-2024, 06:46 PM
Last Post: Puckla
  install debian on pbp jsch 7 12,323 11-22-2023, 04:22 PM
Last Post: TRS-80
  Install deepin OS on pinebook pro wangyukunshan 4 6,830 08-07-2023, 01:12 PM
Last Post: myself600
  Blank screen after Armbian 20.04 install to emmc? psychoacoustic 3 9,618 04-01-2023, 03:22 PM
Last Post: TRS-80
  unsuccessful re-install of OS for PineBookPro Valiance 3 5,248 02-14-2023, 12:49 PM
Last Post: Valiance
  Tow Boot install help Paulie420 7 11,311 11-24-2022, 10:24 AM
